Boiling Bubbling sound coming from the radiator?
toyotasuprauk
When I put my car away yesterday I could hear a bubbling boiling sound coming from the radiator. I thought there was a leak so got it back out again but all looked normal no leaks and there was just a bit of water in the expansion tank.
Later that day driving in the heat in some traffic with the air con on and I noticed that the temperature gauge was higher than normal so I pulled into a car park and I could hear the bubbling sound again. I waited for it to cool down thinking I might need to top up the water but the radiator and the expansion tank where completely full. Then drove home without it overheating.
Anyone got any ideas what this could be, do I need a new rad cap or could there perhaps not been enough coolant in the water? Any suggestions greatly appreciated. :)
[quote name= there was just a bit of water in the expansion tank.
[/quote]
check the coolant level when the engines hot it dumps excess coolant into the expansion tank, as the engine cools down it draws it back into the rad, so when you said there was just a bit of water there should have been about 3/4 of a tank full
[/quote]check the coolant level when the engines hot it dumps excess coolant into the expansion tank, as the engine cools down it draws it back into the rad, so when you said there was just a bit of water there should have been about 3/4 of a tank full
When the cap is knackered too much of the coolant passes into the tank and out on to the road. Leaving a low tank once the system has cooled.
I'm afraid it overheated again today! I had the air con running and the temperature gauge run up to just over 3/4 from a 1/2. I had to open the windows and sit in a traffic jam with the heater on full which wasn't nice but reduced the temperature quickly.
There was the same bubbling sound from the radiator and it looked as if water had been spitting from around the rad cap onto the battery etc. When the car was hot the expansion tank and radiator where completely full.
Rather strangely I drove home a few hours later for about a 30 minute drive expecting to overheat and the temperature was fine and when I stopped there was no bubbling sound although the external temperature was lower.
Maybe I should get the new rad cap first and see what happens. Can I get it from any car place or should it be Toyota?
Was about to post the same problem i've just had with mine going to le mans..
Had the car serviced then we drove over - got to a certain point and i realised the temp was about 3/4 and normally it doesn't budge so i pulled over straight away..
It sounded like lots of bubbling noises... so we let it cool down a bit and took off the rad cap and run the car.. and a few bubbles came up.. So we topped it up with water and off we went... Drove the other 300 miles and it was fine..
Coming back........
Same problem... temp rose but only when i was pushing the car over 70ish...didn't like any strain at all including going up hills... turned on the heater to full and it went down to normal... Just had to drive for 8 hours with the heater on... Going to look at it later as i need some sleep first..
but any ideas or help would be great...
