ronttuk Posted July 4, 2010 Share Posted July 4, 2010 Whats that foam sheet coverd in foil either side called used for insulation between brick walls called ?? Link to comment Share on other sites More sharing options...
Aweegin Posted July 4, 2010 Share Posted July 4, 2010 Celotex Link to comment Share on other sites More sharing options...
ronttuk Posted July 4, 2010 Author Share Posted July 4, 2010 Thats it thanks been trying to remember its name for two days ?? Link to comment Share on other sites More sharing options...
The Raven Posted July 4, 2010 Share Posted July 4, 2010 ££££££££££££££ Link to comment Share on other sites More sharing options...
ronttuk Posted July 4, 2010 Author Share Posted July 4, 2010 Blimy never knew it was expensive !! Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 4, 2010 Share Posted July 4, 2010 Just bought 4 sheets to insulate my up and over garage door. Filling the sections between the spars with it, then putting a milking parlour 3mm white plastic sheet over all the inside to give more light and a neat finish. Link to comment Share on other sites More sharing options...
Rob Posted July 4, 2010 Share Posted July 4, 2010 Blimy never knew it was expensive !! Tis expensive because it performs much better than rockwool for the same thickness, or you can match say 100mm of rockwool with 40mm of Celotex. Link to comment Share on other sites More sharing options...
ronttuk Posted July 4, 2010 Author Share Posted July 4, 2010 I just want it to put under a new liner for my pond lol Link to comment Share on other sites More sharing options...
Rob Posted July 4, 2010 Share Posted July 4, 2010 Is your pond dead flat and square then? Its a rigid board, not like rockwool quilts. I can't help thinking a bag of sand would be a lot, lot cheaper. (a bag of sand, meaning an actual bag of sand, not a thousand pounds) A THOUSAND POUNDS??? OUTRAGEOUS Link to comment Share on other sites More sharing options...
Aero-M Posted July 4, 2010 Share Posted July 4, 2010 You would be much better buying jablight, Loads cheaper than celotex but you do need about 100mm compared to a lot less if using celotex. Shouldn't matter under a pond though Link to comment Share on other sites More sharing options...
ronttuk Posted July 4, 2010 Author Share Posted July 4, 2010 im only going to put the thinnest i think 10mm celutex under the lining its just to stop some roots from a neighbours tree if they get close enough to interfere Link to comment Share on other sites More sharing options...
marcAB10 Posted July 4, 2010 Share Posted July 4, 2010 A THOUSAND POUNDS??? OUTRAGEOUS http://i.ytimg.com/vi/wY6oDAzZUqQ/0.jpg (not just me who thinks that sketch is funny... Pretty sure it's on kids tv too... Lol) Link to comment Share on other sites More sharing options...
Morpheus Posted July 4, 2010 Share Posted July 4, 2010 im only going to put the thinnest i think 10mm celutex under the lining its just to stop some roots from a neighbours tree if they get close enough to interfere Bet your fish will be sweating buckets! Link to comment Share on other sites More sharing options...
Aweegin Posted July 5, 2010 Share Posted July 5, 2010 ..wouldn't a tree route get through celotex, or a derivative though? It's not very resistant to penetration..if you walk on it in boots you leave foot prints... Not that i have a better suggestion..other than maybe a concrete skin, under a butyl one...though, when i was a lad we used to have a pond that was just concrete lined. Depends how close the tree is, if a root can bust though an old stone sewer pipe a pond liner should not prove too difficult Link to comment Share on other sites More sharing options...
Dnk Posted July 5, 2010 Share Posted July 5, 2010 Tree routes get though concrete so cant see that stopping them, cut the tree down or move the pond Link to comment Share on other sites More sharing options...
Rob Posted July 5, 2010 Share Posted July 5, 2010 Alfi, you've clearly not thought this through. Maybe I can help, shall we say a weekly retainer, at £600? Link to comment Share on other sites More sharing options...
ronttuk Posted July 5, 2010 Author Share Posted July 5, 2010 Tree routes get though concrete so cant see that stopping them, cut the tree down or move the pond trees not in my garden!!! cant move the pond its too bloody big 5.5 x 4.5 m the celotex is only being put under the liner to give it a smooth bottom and sides to allow the waste to run clearly to the bottom drain, im not going to concrete it because of the cost i live in rented accom and when my landlord passes on im sure we will be evicted so the son can rent this out for twice what we pay, that could be 6 months time or 5 yrs hes in his 80s already, so the rebuilt pond will have to be removed and filled in when we leave,so im looking for a cheap fix in the meantime Link to comment Share on other sites More sharing options...
Aweegin Posted July 5, 2010 Share Posted July 5, 2010 lol..yeah i know that...its a tad more resilient than celotex though Ah..that's fair play then Alfi...go for it..but check out the different makes then..if jabalite is cheaper for the same effect etc etc..why not Link to comment Share on other sites More sharing options...
