Whitelightning Posted May 26, 2005 Share Posted May 26, 2005 I have squeeky brakes that sound like they are going to be ripped off at any second (at very low speeds only): 1. Pads are not new but are not worn out. So the "new pad squealing" isnt the answer. 2. Disks are new with no warping, so unlike to be the problem. 3. After the wheels were taken off, disks checked - they can spin with limited resistance. Appart from stripping the brakes down, I was wondering if there is anything else the Supra UK brakes are prone to that may cause the "squeek of death" currently occuring ? If it cannot be diagnosed, Im going to strip the brakes down and cover the lot in copperslip Link to comment Share on other sites More sharing options...
Pete Posted May 26, 2005 Share Posted May 26, 2005 Mine are like this too. Annoying isn't it? Wd40? LOL (DON'T EVEN THINK THIS - ANY CHAV MUPPET THAT READS THIS. NEVER PUT OIL ON YOUR BRAKES!) Link to comment Share on other sites More sharing options...
michael Posted May 26, 2005 Share Posted May 26, 2005 Do you have the anti squeel shims installed or a light coating of copper grease on the back of the pads? Which pads are they? Link to comment Share on other sites More sharing options...
Aerotop Dave Posted May 26, 2005 Share Posted May 26, 2005 Now I get this and I was told it's just brake dust. It's a right earful with the roof off. A damn good stamp on them at the first junction clears the crap out and they are squeal free after that. Link to comment Share on other sites More sharing options...
SupraLuigi Posted May 26, 2005 Share Posted May 26, 2005 I've just had the squeal and the only way to fix it was new pads on the fronts although the other pads looked new anyway Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 26, 2005 Share Posted May 26, 2005 Toyota do an anti squeal shim kit, you can use Copaslip grease, or you can try different pads. The correct way to test for bind is with the wheels ON and torqued up, as the wheel studs also clamp the brake discs. Link to comment Share on other sites More sharing options...
Tigger Posted May 26, 2005 Share Posted May 26, 2005 I've just had the squeal and the only way to fix it was new pads on the fronts although the other pads looked new anyway Those one squealed cause they were racing something or other. Not really road/everyday use;), but I got use to it in the end. Still loving the car? Link to comment Share on other sites More sharing options...
Miguel Posted May 26, 2005 Share Posted May 26, 2005 See if the anti squeal shims are in there if not Mr copperslip is your friend. Link to comment Share on other sites More sharing options...
SupraLuigi Posted May 26, 2005 Share Posted May 26, 2005 Tigger, Cars great, big service, new brakes - just dont get to drive it enough! Link to comment Share on other sites More sharing options...
Ian C Posted May 26, 2005 Share Posted May 26, 2005 CW fast road pads don't squeal even without anti-squeal shims and copperslip -Ian Link to comment Share on other sites More sharing options...
Whitelightning Posted May 27, 2005 Author Share Posted May 27, 2005 Hmmmm who took out my CW pads then ? Link to comment Share on other sites More sharing options...
