LSD DIFF rebuild cost?
rob wild
Well looks like my bad luck continues. I decide to check my diff (6 speed LSD) after its been making a noise above 50 mph when on and off the power.
Start off by dropping the fluid and what a mess :(
Spoke to Mr T and he wanted £2200 :blink: So looking at prices for a rebuild. Just wondering if anyone knew anywhere that could rebuild them and how much?
I've contacted a few places and got a few quote already.
Is it the diff or the Crown that's gone? If it's the diff then a TRD item is sure to be the best option in terms of cost and reliabilty?
Diff is about £550, seals and other bits are about £150, then they need setting up. So £800-£850 would be about right.
Not sure until I strip it which bit has gone tbh D but I'm expecting it to need fully rebuilding. That amount of swarf can't be good.
I think you're right though at 800-900. Might look into a TRD diff or even a OS Giken if RB motorsport end up rebuilding it.
Rob,
As a complete noob when it comes to LSD's, how do you mean makes a noise above 50? Just I'm investigating something myself at the moment. I just thought LSDs came into play when cornering?
Sorry for the noob Q, I'll find some links on the net if its difficult to explain. Cheers.
If it's whining in a straight line it's surely got to be the ring/crown/pinion, which would have fecked the rest of it. Not good :(
Is this the diff from the same tw*t that sold you the 6spd conversion kit that had the wrong prop shaft?
Rob,
No problem, its not making a noise when the LSD is in operation and as far as I can tell the LSD is working. Its making a noise when cruising at about 50 or more and gentle coming on and off the power.
I will have a 6 speed lsd available soon, (not the case but the lsd)
Cheers Jamie maybe a good option, how much? Feel free to PM :)
The whole thing will be *uggered, look for a good used complete assembly. The labour costs of shimming that up, together with new internals will be horrendous. You should be able to pick up a complete assembly idf you search about.
Cheers Chris, just out of interest how much would you charge for rebuilding something like that?
If it's whining in a straight line it's surely got to be the crown/pinon, which would have fecked the rest of it. Not good :(
Yeah its buggered big time :(
Yep the very same! :rolleyes:
Thanks Rob, appreciate the post. What kind of noise is it?
Either way, I hope you get it sorted mate.
Just for reference my TRD diff was £715 with the fitting kit, plus delivery from USA.
I got import duty on top of that.
Fitting/shimming by a specalist is about £300, then ive got to pay Lee to fit it in the car...... not cheap when you add that lot up.
£100+post for the used lsd, wont be available for a few days. EDIT.. that is just the internal LSD, no case.
Edited by JamieP (see edit history)
Rob Im pretty sure I have the internals of a diff here, I will need to ask terry where it came from but if its the same as yours then it will get you out of trouble, I do not know if the Ring and pinion is on it though.
It must be the time of year for this!
Mine's also making a good deal of noise when driving over 50. I'm pretty sure is up the swanny, so will be dropping the oil to see if it's got a similar amount of metal floating around it as this.
£2200 for a new one! :faint:
