Odd idling problem + Red Warning triangle
garetheves
Ok this could take a while to explain so please bear with me cos its got me a bit worried.
A number of weeks ago the red warning triangle started to come on while driving. No apparent cause or regular pattern and it only stayed on for a few seconds and then went off. No problem. Had a chat with a few people on here and they thought it was more than likely the brake fluid level a little low. Anyway work has been really busy and havent got round to sorting it yet. Its gradually been coming on for longer and longer until day before yesterday was on for entire half hour journey (a bit worrying as im sure you can imagine).
Now heres the weird bit and it may be completely unrelated and a complete coinsidence, but i think not. Drove round to Maccy D's last night and while parked in car park eating, the car idled very low, so low in fact i thought it was gonna cut out. Made the car actually shake. Did this on a and off for bout 10 mins until i set off and it very nearly stalled, despite high revs. Then for the enxt 30 mins of driving, very slowly i might add, it actually did cut out regularly and very briefly. it was as if the car had been turned off and back on again quickly. Made the car lurch forward as it decelerated a bit, then lurch again as it started again. After bout half hour or so it stopped and havent had a problem since, although have been taking it very easy.
Basically im wondering 2 things:
1. WTF is up with it.
2. Are the triangle and the idling linked in some way.
Any help would be much appreciated.
Cheers in advance.
Gaz
P.S. sorry for the long post but i feel its easier with as full a description as possible.
Its a J-Spec. Use the same fuel from the same station every time. The warning light has been there a while now, just staying on longer and longer. The missfiring seemed to start with about just over quater of a tank left. Happened again this morning when i took it out.
Hi,
Don’t reset the ECU- this will clear the codes.
Basically the car has logged the fault as the triangle has come on.
Once you have done the error code test the fault will show up.
Sounds like a faulty sensor somewhere. Possible MAP sensor or idle control valve.
Let us know.
Yep, you are doing something wrong :) It's not a plastic coated paperclip is it har har :)
But seriously, if you've done it right you'll either get a regular flash indicating no stored codes, or the code numbers will be flashed. A steady light means it's not in diagnostic mode.
Incidentally, bridging those two pins puts the engine into limp-home mode as well so don't forget to remove it afterwards...
-Ian
Is it the engine warning light that flashes and not the triangle?
From your description it sounds exactly the same as what my car did after fitting my FCD badly, and having a dry joint on the 12V to the ECU under the passenger footwell, the FCD signal was gone completely so it didn't know where to idle or what revs I was at when pulling away!
Its defo not a plastic coated one. dont know what im diong wrong though. Im assuming you dont turn the engine on fully, just turn it to position 2 when all the warning lights come on.
Also is 15W/40 oil ok for a decatted TT?
So you've got pins TE1 and E1 shorted in the diag port (you've not got a VVTi I assume:) ) and you turn the ignition to position 2 *and deimmobilise the car* and the light is just lit up? Hmmm.
-Ian
