SupraAyf Posted August 31, 2009 Share Posted August 31, 2009 Fellas, Can one of you help me calculate what size wheels I would need for my car. My Supra is 50mm wider either side at the rear than a standard Supra and 33mm wider either side at the front. I have read this: http://www.usacomp.com/terms.htm but it has advice like the following extract which means bugger all to me:( OFFSET The offset of a wheel is the measurement of the hub surface contact area in offset from the center line of the overall rim width of the wheel. A wheel whose hub surface contact area sits further towards the outside of the wheel than the center line has a positive offset. A wheel whose hub surface contact area sits further towards the inside of the wheel than the centerline has a negative offset .. Link to comment Share on other sites More sharing options...
Scooter Posted August 31, 2009 Share Posted August 31, 2009 This will hopefully make it clearer........ If you fitted wheels with the same spec as stock 17's (8" ans 9.5" and 50 offset) then you would need to order them with a offset on the front of 17 and an offset on the rear of 0, to get the same look. if you fitted say 9" and 10.5" wheels then you'd need..... 29.7mm offset fronts (12.7mm re half the extra inch wider front) 12.7mm offset rears (again the same additional half inch width) consider the effect of extra wheel width and the change in offset sperately and then add the effects together...........do the current wheels not have offset and width info on them? If you know that and want them in or out a little bit more that should be easy to work out......... Link to comment Share on other sites More sharing options...
SupraAyf Posted August 31, 2009 Author Share Posted August 31, 2009 Thanks Scooter;), I think it makes sense but I'll sit down and read it a few times. My car is not in the same country as me at the moment but I will check it out when I get back mate. I'm going to have to get a pen and paper and draw a diagram or something (simple minds and simple things:D). Thanks for your help - much appreciated indeed! Link to comment Share on other sites More sharing options...
farmer Posted August 31, 2009 Share Posted August 31, 2009 God i hope this helps, it seems easy but then E=MC}2 is to some folk. http://www.1010tires.com/WheelOffsetCalculator.asp http://www.morfed.net/wheel-offset-calculator/ http://marksink.com/tire_wheel_offset/offset.html Link to comment Share on other sites More sharing options...
Homer Posted August 31, 2009 Share Posted August 31, 2009 Can one of you help me calculate what size wheels I would need for my car. My Supra is 50mm wider either side at the rear than a standard Supra and 33mm wider either side at the front. Are those widths the increase in distance over stock of the inner arch or the outer arch? Also, how low is the car? If you can confirm I'll stick it into the tyre size calculator and see what it provides. Link to comment Share on other sites More sharing options...
SupraAyf Posted August 31, 2009 Author Share Posted August 31, 2009 Are those widths the increase in distance over stock of the inner arch or the outer arch? Also, how low is the car? If you can confirm I'll stick it into the tyre size calculator and see what it provides. Homer, the sizes refer to the outer arches only. The standard arches have been fully cut away and the bodykit has been blended on top - I hope that makes sense. I'm not exactly sure on heights but the Hyermax II suspension system is set at approx 1-inch lower than stock. Link to comment Share on other sites More sharing options...
Homer Posted August 31, 2009 Share Posted August 31, 2009 Homer, the sizes refer to the outer arches only. The standard arches have been fully cut away and the bodykit has been blended on top - I hope that makes sense. I'm not exactly sure on heights but the Hyermax II suspension system is set at approx 1-inch lower than stock. Do you happen to know if there is a lip on the inside of the new arch? If there is, is it any deeper than stock? I'd imagine it's less or has almost none, which should help give a bit of leeway Link to comment Share on other sites More sharing options...
SupraAyf Posted August 31, 2009 Author Share Posted August 31, 2009 Homer, here's a side pic: Link to comment Share on other sites More sharing options...
SupraAyf Posted August 31, 2009 Author Share Posted August 31, 2009 I'd imagine it's less or has almost none, which should help give a bit of leeway I belive there is no lip Homer Link to comment Share on other sites More sharing options...
JamieP Posted August 31, 2009 Share Posted August 31, 2009 I would wait till you get home and measure up the wheels you have now and go from there, they are easy to measure. Link to comment Share on other sites More sharing options...
Supranature Posted August 31, 2009 Share Posted August 31, 2009 Whats wrong with those wheels, Andrew? Look sweeeeet to me. Love that side view of your car. Stunning. Link to comment Share on other sites More sharing options...
SupraAyf Posted August 31, 2009 Author Share Posted August 31, 2009 That's really usefull and I fully understand what I need to measure now. I have to admit but I don't find this wheel stuff easy:( Cheers guys!! Link to comment Share on other sites More sharing options...
Homer Posted August 31, 2009 Share Posted August 31, 2009 The pic Jamie posted is very helpful 19 inch wheels yes? Using the terms from that diagram, if you want to retain the stock inboard width (best to avoid rubbing issues on the inner arch), the closest rear wheel size would be: 305/30 x19 tyre 11x19 -28 wheel Front: 275/35 x19 tyre 9.5x19 -38 wheel (10x19 also should work, but might rub on the inner arch) The offsets with these sizes will help stop screwing up the suspension geo too much. Link to comment Share on other sites More sharing options...
JamieP Posted August 31, 2009 Share Posted August 31, 2009 Id go with a 12" rear to get some more rubber on the floor, to late to get my head round them numbers Homer but have you worked that out so the wheels sit in the arches the same as stock? if so id go another 15-20mm on them offsets to give a nice aggresive look. Link to comment Share on other sites More sharing options...
Homer Posted August 31, 2009 Share Posted August 31, 2009 Id go with a 12" rear to get some more rubber on the floor, to late to get my head round them numbers Homer but have you worked that out so the wheels sit in the arches the same as stock? if so id go another 15-20mm on them offsets to give a nice aggresive look. Yep, the sizes are worked to be as close to stock with the same arch clearance. As you say, they can be increased for a more agressive look, but run a greater risk of rubbing. Best to wait until the car arrives until ordering anything as it'll give a better idea what to go for and how much room there is to play with. Link to comment Share on other sites More sharing options...
