adnanshah247 Posted July 16, 2009 Share Posted July 16, 2009 well my valve seals seem ko'd. the car lets out a decent sized blue puff every time i either, rev to pull off while the engine is on and stand still and it lets the smoke out on start. once running and driving no smoke at all. running a single that i drive pretty hard i think i should get the work done before i damage anything...... my questions are:- 1. is this why my car is gradually using tiny bits of oil. 2. do leaky valve seals dent the overall power output of the car? 3. my mechanic said get a head gasket kit because the valve seals come with it. is this true? 4. what is the best kit to get that will sort my problem? 5. while the work is done, the head is off, should i do anything else while its all taken apart? i know the head will need to be skimmed but anything else? thanks. p.s. JamieP and Ashbhp, mention my warm up techniques and ill kik ur a$$'s! (i promise ever since then ive not revved the nuts off it and let it warm up perfectly and cool down.) Link to comment Share on other sites More sharing options...
absz Posted July 16, 2009 Share Posted July 16, 2009 you can replace the seals without removing head. the stems seals can be bought separate. good luck:d Link to comment Share on other sites More sharing options...
adnanshah247 Posted July 16, 2009 Author Share Posted July 16, 2009 you can replace the seals without removing head. the stems seals can be bought separate. good luck:d hey? arent the valves under the engine head??? if the headgasket comes out wouldnt it be best to put that in as well? Link to comment Share on other sites More sharing options...
stevie_b Posted July 16, 2009 Share Posted July 16, 2009 5: why would the head need to be skimmed? I thought that was only when the engine overheats, and the head warps (hence needs skimming to bring it back to a flat surface). Link to comment Share on other sites More sharing options...
Steve Posted July 16, 2009 Share Posted July 16, 2009 http://www.mkivsupra.net/vbb/showthread.php?t=49859 Link to comment Share on other sites More sharing options...
heckler Posted July 16, 2009 Share Posted July 16, 2009 hey? arent the valves under the engine head??? if the headgasket comes out wouldnt it be best to put that in as well? the valves are, but the seals are under the shims and are accessable by taking the cams, and shims etc out... Link to comment Share on other sites More sharing options...
j1mb0b1 Posted July 16, 2009 Share Posted July 16, 2009 p.s. JamieP and Ashbhp, mention my warm up techniques and ill kik ur a$$'s! (i promise ever since then ive not revved the nuts off it and let it warm up perfectly and cool down.) Yup I have also witnessed your warm up first hand, I would have to say that your Valve stem seals are nacked due to this. Link to comment Share on other sites More sharing options...
SteveR Posted July 16, 2009 Share Posted July 16, 2009 p.s. JamieP and Ashbhp, mention my warm up techniques and ill kik ur a$$'s! (i promise ever since then ive not revved the nuts off it and let it warm up perfectly and cool down.) TBH mate that was the dumbess thing I've seen a forum member do. I thought you had a problem - I didn't realise you were doing that deliberately. Do you know how to warm up an engine properly? (Genuine question I'm not taking the piss I just don't want to see you end up with big problems like this again!) Link to comment Share on other sites More sharing options...
adnanshah247 Posted July 16, 2009 Author Share Posted July 16, 2009 Yup I have also witnessed your warm up first hand, I would have to say that your Valve stem seals are nacked due to this. ! it was only once! leave me alone! lol Link to comment Share on other sites More sharing options...
RobSheffield Posted July 16, 2009 Share Posted July 16, 2009 Lolololol Link to comment Share on other sites More sharing options...
adnanshah247 Posted July 16, 2009 Author Share Posted July 16, 2009 TBH mate that was the dumbess thing I've seen a forum member do. I thought you had a problem - I didn't realise you were doing that deliberately. Do you know how to warm up an engine properly? (Genuine question I'm not taking the piss I just don't want to see you end up with big problems like this again!) no seriously beyond a joke, i just said that because it was the first thing that came to my head. i always since day one on all my turbo cars, allow the car to easily warm up and cool down before i switch on and off. the only thing i didnt know was that excessive revving of the engine is unhealthy for it, you know i think it was jamie saying that getting the cars engine to the rev limiter was really bad. but i never used to push the car to the limiter anyways. think about it steve, that bit when i was revving, i had been out about 5 minutes before hand, the engine didnt need warming up, it was already warm. i done a lot of reading but i think i have had a genuine fault rather than foooking about and causing issues with the car. Link to comment Share on other sites More sharing options...
Robert Posted July 16, 2009 Share Posted July 16, 2009 You drive like a C0ck so i say it's your fault!!! Link to comment Share on other sites More sharing options...
adnanshah247 Posted July 16, 2009 Author Share Posted July 16, 2009 You drive like a C0ck so i say it's your fault!!! your just jealous. lol dont make me call my russian mafia friends. that shut u up didnt it! lol Link to comment Share on other sites More sharing options...
Homer Posted July 16, 2009 Share Posted July 16, 2009 You drive like a C0ck so i say it's your fault!!! Sorry Adnan, but with the stuff I've seen on vids you're going to blow something before long. The turbo is likely first... If the valve seats are shot it'll need the head off and rebuilt. Expensive, but do it right and it should see you some years useage. Are you still using antilag? That isn't going to help things! Hope you have deep pockets, without a hole in them Link to comment Share on other sites More sharing options...
Robert Posted July 16, 2009 Share Posted July 16, 2009 your just jealous. lol dont make me call my russian mafia friends. that shut u up didnt it! lol it didn't, i aint scared of them so you make no difference! Link to comment Share on other sites More sharing options...
adnanshah247 Posted July 16, 2009 Author Share Posted July 16, 2009 i just got told off by darryl. im upset now. screw you rob! this engine is yours by the way remember! lol im opening a dispute thread! Link to comment Share on other sites More sharing options...
Robert Posted July 16, 2009 Share Posted July 16, 2009 Go ahead, was fine the day you fitted it and mapped it, it was after you went on a stupid MJ cruise it broke, don't blame me!! Link to comment Share on other sites More sharing options...
adnanshah247 Posted July 16, 2009 Author Share Posted July 16, 2009 i think i went a little ott that night. anyways, going to get all the work done now so should have a fresh piece of kit for ryan to map up for me. Link to comment Share on other sites More sharing options...
Guest exceed Posted July 16, 2009 Share Posted July 16, 2009 Whoa fuck me mate, you don't just rev an engine up from cold... Lol I guess you've caught the problem before it grew too big though, so kudos for that. And add an oil temp gauge (or map in more safety parameters) so that you know when you can rev it up (although even when hot its not ideal to hold it at the limiter!). Lol sounds like something I would have done in my first car!! Link to comment Share on other sites More sharing options...
supra dan Posted July 16, 2009 Share Posted July 16, 2009 time to give the guy a break perhaps? Link to comment Share on other sites More sharing options...
RobSheffield Posted July 16, 2009 Share Posted July 16, 2009 time to give the guy a break perhaps? Give it a day Link to comment Share on other sites More sharing options...
caseys Posted July 17, 2009 Share Posted July 17, 2009 Hey Adnan, Just had my head rebuilt after getting slowly more and more smokey with valve stem seals. I thought if I took it in for an MOT with that going as it was I'd just be taking the p***. That and my rear crank seal was leaking. After having the head taken off we found out how damn coked up it was, I was only going to have the valve stem seals replaced but whilst the head was off I got the intake and exhaust valves done (some even replaced). The head had a nice old clean whilst it was out too. Also an ARP kit and all gaskets would be a good idea whilst you're at it? I'm just about to put up a little thread in Supra Chat showing the work, I'll add a link when I've done it. Link to comment Share on other sites More sharing options...
dude Posted July 17, 2009 Share Posted July 17, 2009 Do NOT get the head skimmed unless it absolutley needs it dude, if your oil seals are bad the chances are that the exhaust side will be full of nice hard carbon and as in caseys case!!! the exhaust valves and seats will be badly pitted. Link to comment Share on other sites More sharing options...
caseys Posted July 17, 2009 Share Posted July 17, 2009 http://www.mkivsupra.net/vbb/showthread.php?p=2446034#post2446034 Is my thread showing more work, done by Dude above! Link to comment Share on other sites More sharing options...
SteveR Posted July 17, 2009 Share Posted July 17, 2009 (edited) ...i think it was jamie saying that getting the cars engine to the rev limiter was really bad. but i never used to push the car to the limiter anyways. think about it steve, that bit when i was revving, i had been out about 5 minutes before hand, the engine didnt need warming up, it was already warm. Fair enough cheif. I know you've put a lot off time & effort into th car and none of us like bills we can avoid. You know you're doing something bad if even JamieP is saying he wouldn't do it! BTW it may surprise you but I didn't track your every move at Llandow so didn't know if you'd driving about, on track or elsewhere. I just heard the revving, was confused, and then let you get on with it. Edited July 17, 2009 by SteveR alot = a lot (see edit history) Link to comment Share on other sites More sharing options...
