fizzle Posted June 7, 2009 Share Posted June 7, 2009 right guys this is getting ridiculous... spent hours yesterday taking apart, checking connections, fuses, disconnect battery etc like the other posts on this suggests but still no joy.. it will lock, but won't unlock, by fob or manually.. its quite embarrassing climbing into a nice car through the boot, i'm not small so doesn't make it very easy or graceful diving head first into back seats[sHOCK][/sHOCK] ( although secretly it makes me feel like a duke of hazzard) does anyone have any further suggestion or am i going to have to let toyota rip me off??? p.s the windows work fine! Link to comment Share on other sites More sharing options...
The Raven Posted June 7, 2009 Share Posted June 7, 2009 I will only help if you film yourself outside the local supermarket getting into the car. I would guess at a fault in the wiring. Does it do it both sides with the key? Link to comment Share on other sites More sharing options...
fizzle Posted June 7, 2009 Author Share Posted June 7, 2009 using the key, it will only lock on the drivers side but the passenger side doesn't work at all.. Link to comment Share on other sites More sharing options...
Konrad Posted June 7, 2009 Share Posted June 7, 2009 Small connector in drivers door, 3 cables going in and out, it's white and located around inside door handle area. Disconnect it and try opening/closing doors then. Link to comment Share on other sites More sharing options...
The Raven Posted June 7, 2009 Share Posted June 7, 2009 using the key, it will only lock on the drivers side but the passenger side doesn't work at all.. And it refuses to unlock with the key on both sides? Link to comment Share on other sites More sharing options...
fizzle Posted June 7, 2009 Author Share Posted June 7, 2009 cant find one with 3 cables?? theres a grey one with 4 and a white one with 5 behind the lock/handle area... Link to comment Share on other sites More sharing options...
fizzle Posted June 7, 2009 Author Share Posted June 7, 2009 And it refuses to unlock with the key on both sides? yep Link to comment Share on other sites More sharing options...
The Raven Posted June 7, 2009 Share Posted June 7, 2009 yep Hmm, Has to be a wiring fault somewhere, have you tried pulling back the rubber between the door and the wing and taking a look, Most breaks happen in there. Failing that i would get a proper car sparky in to fix it. Link to comment Share on other sites More sharing options...
tomgeer Posted June 7, 2009 Share Posted June 7, 2009 Try your spare key, one of mine doesn't unlock the drivers door or boot. Link to comment Share on other sites More sharing options...
fizzle Posted June 7, 2009 Author Share Posted June 7, 2009 WOOOO HOOOOO fixed it, was a loose connection on the back of the passenger lock barrel (3 small wires, lol) accidently poked it and heard doors click, removed it cleaned it then replaced and all good... thanks for your help guys... Sorry no video of me diving in thru boot @ sainsbury's now!! Link to comment Share on other sites More sharing options...
The Raven Posted June 7, 2009 Share Posted June 7, 2009 WOOOO HOOOOO fixed it, was a loose connection on the back of the passenger lock barrel (3 small wires, lol) accidently poked it and heard doors click, removed it cleaned it then replaced and all good... thanks for your help guys... Sorry no video of me diving in thru boot @ sainsbury's now!! DAM! i wanted to see that:p Happy days none the less;) Link to comment Share on other sites More sharing options...
TRACIE_LOU Posted June 7, 2009 Share Posted June 7, 2009 Sorry no video of me diving in thru boot @ sainsbury's now!! You could just do it anyway just to amuse us!!! Link to comment Share on other sites More sharing options...
The Raven Posted June 7, 2009 Share Posted June 7, 2009 You could just do it anyway just to amuse us!!! Agreed or no help in the future:p Link to comment Share on other sites More sharing options...
pistonbroke Posted June 7, 2009 Share Posted June 7, 2009 You could just do it anyway just to amuse us!!! I concur, Link to comment Share on other sites More sharing options...
Kirk Posted June 7, 2009 Share Posted June 7, 2009 Link to comment Share on other sites More sharing options...
TRACIE_LOU Posted June 7, 2009 Share Posted June 7, 2009 Hehehe... Looks like you got no choice but to do it now!!..:d Link to comment Share on other sites More sharing options...
Scott Posted June 7, 2009 Share Posted June 7, 2009 Does the key now open the doors? I always thought the door lock was mechanical and that the key would open it regardless of the central locking condition. Link to comment Share on other sites More sharing options...
The Raven Posted June 7, 2009 Share Posted June 7, 2009 Does the key now open the doors? I always thought the door lock was mechanical and that the key would open it regardless of the central locking condition. Thats why i asked, I always thought the key would overide the C/L and open the door Link to comment Share on other sites More sharing options...
pistonbroke Posted June 7, 2009 Share Posted June 7, 2009 Unless the motor was constantly pushing the lock closed due to an electrical fault. Link to comment Share on other sites More sharing options...
Scott Posted June 7, 2009 Share Posted June 7, 2009 Unless the motor was constantly pushing the lock closed due to an electrical fault. Yeah i could see that happening but the key would still open the door for a split second before the motor pushed it back surely? I've had it with the MR2, when it had a short, where i would open the door and the central locking would instantly close it again. I got some feedback though, so i knew it was a wiring issue and nothing mechanical. This problem is quite worrying, to me anyway. I would hate to be in an accident and not be able to get the doors open. Link to comment Share on other sites More sharing options...
pistonbroke Posted June 7, 2009 Share Posted June 7, 2009 Unless the car has deadlocks (which I think the supra doesn't), the interior handle will always override the locking system and opens the door latch mechanism. So you should always be able to open the door from the inside. Link to comment Share on other sites More sharing options...
Scott Posted June 7, 2009 Share Posted June 7, 2009 Unless the car has deadlocks (which I think the supra doesn't), the interior handle will always override the locking system and opens the door latch mechanism. So you should always be able to open the door from the inside. Ahh thats not so bad then Link to comment Share on other sites More sharing options...
