Rob Dublin Posted May 13, 2009 Share Posted May 13, 2009 Oh right, so it's Ireland specfic! you didn't say that now did you rob!! No, I didn't.... Claire did :p hmmm i need to reset ecu If you just disconnect the battery for 5-10 mins it resets the battery (I think) Easier than pulling fuses. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted May 13, 2009 Share Posted May 13, 2009 Rob I think to run a car on Maxol's E85 fuel the car must be a flexi-fuel car or be mapped to run on it. Are you sure you don't mean the E5 fuel which they offer? It apparently is 98-99 Ron but is perfectly suited to any car (unleaded) I use it in my prelude and will use it in the supra when ready. Quote Link to comment Share on other sites More sharing options...
Rob Dublin Posted May 13, 2009 Share Posted May 13, 2009 I stand corrected... I meant E5 not E85. Cheers. Quote Link to comment Share on other sites More sharing options...
Matt H Posted May 13, 2009 Share Posted May 13, 2009 So you can get higher RON fuel in Ireland then?!?! Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted May 13, 2009 Share Posted May 13, 2009 Yep, straight off the forecourt for €1.06 a litre!! Quote Link to comment Share on other sites More sharing options...
tony tt Posted May 13, 2009 Share Posted May 13, 2009 I had my supra j spec tt in ireland for a year running 95ron with octane boost as a result i blew a turbo and melted a cylinder cost me 5000euro for another engine after fitting it i was told to run 0.9bar only because any higher and it was causing major problems for the car through time. As a result i moved to the uk for better fuel 95ron is an issue for a j spec tt the only 2 options you have to run the car safely is an aftermarket ecu and mapped for 95ron with lower boost levels certainly not 1.2bar. or use the maxol e5 only and nothing else. Quote Link to comment Share on other sites More sharing options...
Rob Dublin Posted May 13, 2009 Share Posted May 13, 2009 From Maxol.ie " The Octane Rating of Ordinary unleaded ranges from 95.0 to 95.9 – average 95.5. The Octane rating of E5 is higher and has been measured at 99. " Didn't think it was that high. That should be problems solved so. Question becomes "how do I get more ethanol to take it over 100 Ron" Quote Link to comment Share on other sites More sharing options...
ClaireRZ-S Posted May 13, 2009 Author Share Posted May 13, 2009 Ahh ok theres a maxol near me so i just go in a use the E5 there i always use to go to Topaz they've lost my business now Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted May 13, 2009 Share Posted May 13, 2009 Not all stations do it Claire. Here ya go: http://www.maxol.ie/general-content/e5-stations.html Quote Link to comment Share on other sites More sharing options...
tony tt Posted May 13, 2009 Share Posted May 13, 2009 You will feel a bit more power with the e5 claire your car will run a lot happier Quote Link to comment Share on other sites More sharing options...
ClaireRZ-S Posted May 13, 2009 Author Share Posted May 13, 2009 crap no E5 near me at all. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted May 13, 2009 Share Posted May 13, 2009 Thats terrible:sly:, I can see my E5 pump from my front door:p Quote Link to comment Share on other sites More sharing options...
tony tt Posted May 13, 2009 Share Posted May 13, 2009 new ecu and remap by look of it then. Thats why i moved to the uk it was always in the back of my mind my engine was going to pop again. Dont run above 1bar on 95 clare. Quote Link to comment Share on other sites More sharing options...
jamesmark Posted May 13, 2009 Share Posted May 13, 2009 I had my supra j spec tt in ireland for a year running 95ron with octane boost as a result i blew a turbo and melted a cylinder cost me 5000euro for another engine after fitting it i was told to run 0.9bar only because any higher and it was causing major problems for the car through time. As a result i moved to the uk for better fuel 95ron is an issue for a j spec tt the only 2 options you have to run the car safely is an aftermarket ecu and mapped for 95ron with lower boost levels certainly not 1.2bar. or use the maxol e5 only and nothing else. Or Ireland to get out of the dark ages. Quote Link to comment Share on other sites More sharing options...
tony tt Posted May 13, 2009 Share Posted May 13, 2009 Or Ireland to get out of the dark ages. Apparently they use to sell higher octane fuel mate but the govt banned it to keep high performance cars from gettin imported or something not too sure. I certainly got a shock when i moved there from ayrshire! Quote Link to comment Share on other sites More sharing options...
Rob Dublin Posted May 13, 2009 Share Posted May 13, 2009 Go talk to the manager of the station or get on to Maxol themselves. Can't hurt to give them a nudge. Short skirt might help Quote Link to comment Share on other sites More sharing options...
tony tt Posted May 13, 2009 Share Posted May 13, 2009 Go talk to the manager of the station or get on to Maxol themselves. Can't hurt to give them a nudge. Short skirt might help If theres enough demand in the area it should swing them to get the e5 to that station it worked in tralee im sure. Quote Link to comment Share on other sites More sharing options...
