SupraTRD83 Posted January 30, 2009 Share Posted January 30, 2009 Right I have installed some 2 x HB3 65 Watt Dipped (driving) beam bulbs now i want to upgrade the ICE White sidelight bulbs so i obviously havent got pure white then yellow sidelights (looks ) so how do i replace the sidelights? cant seem to get my bloody hand to them to replace???? Quote Link to comment Share on other sites More sharing options...
ClaireRZ-S Posted January 30, 2009 Share Posted January 30, 2009 Use the search button!!!! Quote Link to comment Share on other sites More sharing options...
Havard Posted January 30, 2009 Share Posted January 30, 2009 Aren't you the sae guy who was exploding over his headlights the other day?? (for want of a bettter expression!!) H. Quote Link to comment Share on other sites More sharing options...
SupraTRD83 Posted January 30, 2009 Author Share Posted January 30, 2009 yeh thats me, got the headlight beam lights in but cant find where to get to the sidelights, tried searching cant find anything Quote Link to comment Share on other sites More sharing options...
Axle Posted January 30, 2009 Share Posted January 30, 2009 Use the search button!!!! Why did you not do the same only last week?... Hi Sorry for the silly question but i just don't know. Since new bumper was put on the indicator to the right dont work. The indicator just makes a quick clicking noise. Its the clear indicator thats in the bumper and the orange one thats stuck onto the side of the bumper. They both don't work . The orange one to the left doesn't work either, will both stop working if one does'nt work?? Just wondering do you know what bulbs i need for this as i'm going to try and get it fixed tomorrow. Thanks. Quote Link to comment Share on other sites More sharing options...
ClaireRZ-S Posted January 30, 2009 Share Posted January 30, 2009 Why did you not do the same only last week?... I did search and i didn't find anything about the bulbs i was looking for. I presumed they were different since my car is jspec Quote Link to comment Share on other sites More sharing options...
Axle Posted January 30, 2009 Share Posted January 30, 2009 I did search and i didn't find anything about the bulbs i was looking for. I presumed they were different since my car is jspec Ok, so next time would it not be fair to presume he did the same? yeh thats me, got the headlight beam lights in but cant find where to get to the sidelights, tried searching cant find anything Quote Link to comment Share on other sites More sharing options...
AlanM Posted January 30, 2009 Share Posted January 30, 2009 Gave you all the advice I could when you were calling your dipped beam sidelights, try reading that thread now Quote Link to comment Share on other sites More sharing options...
ClaireRZ-S Posted January 30, 2009 Share Posted January 30, 2009 Ok, so next time would it not be fair to presume he did the same? Maybe i presumed he didn't due to all the threads on this recently. I'll try not throw up the worthless threads if you do the same Quote Link to comment Share on other sites More sharing options...
AlanM Posted January 30, 2009 Share Posted January 30, 2009 Even found the thread for you http://www.mkivsupra.net/vbb/showthread.php?t=175453 Quote Link to comment Share on other sites More sharing options...
Axle Posted January 30, 2009 Share Posted January 30, 2009 I'll try not throw up the worthless threads if you do the same Touchy. First, get your facts straight - I didn’t say anything about you throwing up a 'worthless' thread or otherwise. Unless you are mistaking me for others who have? Secondly, can you point me to the 'worthless thread' in question? Third, start acting your age. Fourth, im off to eat some tuna. Quote Link to comment Share on other sites More sharing options...
Dave Posted February 2, 2009 Share Posted February 2, 2009 sidelightbulbs are attached to a long plastic insert in your headlight casing rear. if your looking at the light from above its bottom left for left side and bottom right for right side. give it a twist and pull out be carefull you dont dislodge the bulb and it falls in the headlite otherwise you will have to remove the headlite to get it out [ like i did ] Quote Link to comment Share on other sites More sharing options...
SupraTRD83 Posted February 11, 2009 Author Share Posted February 11, 2009 sidelightbulbs are attached to a long plastic insert in your headlight casing rear. if your looking at the light from above its bottom left for left side and bottom right for right side. give it a twist and pull out be carefull you dont dislodge the bulb and it falls in the headlite otherwise you will have to remove the headlite to get it out [ like i did ] Done cheers and cheers Axle Quote Link to comment Share on other sites More sharing options...
Animal Posted February 11, 2009 Share Posted February 11, 2009 Is the actual [continued on next post] Quote Link to comment Share on other sites More sharing options...
