Smellywelshman Posted January 13, 2009 Share Posted January 13, 2009 Dead easy to check the alternator to see though (after checking the crank pulley), just put a multimeter across the battery when the cars on idle, a value of around 13v means its working ok and charging the battery. Less than this and its duff! Link to comment Share on other sites More sharing options...
SteveR Posted January 13, 2009 Share Posted January 13, 2009 Are your battery cables connected both adequately and securely? Link to comment Share on other sites More sharing options...
supraspeed Posted January 13, 2009 Author Share Posted January 13, 2009 Are your battery cables connected both adequately and securely? yup, all connections are fine Link to comment Share on other sites More sharing options...
Swampy442 Posted January 13, 2009 Share Posted January 13, 2009 If it is the alternator, might be worth getting it reconditioned as opposed to getting a second hand one, at least that way you have a warantee. Link to comment Share on other sites More sharing options...
and1c Posted January 13, 2009 Share Posted January 13, 2009 As others have said, crank pulley is the obvious suspect if all ancilleries failed. You can manually check it by hand if the car wont start.See is there is any play or any visual damage up close... Or// remove the battery, stick it on a charger overnight (you need to do this asap anyway, a good pulse charger really) and then start the car the next day. ONLY to check the crank pulley though. As others have said, if its gone that badly then it will not spin true...andy wobbles and thats the culprit and you should have it replaced by someone who knows what they are doing....! Link to comment Share on other sites More sharing options...
supraspeed Posted January 13, 2009 Author Share Posted January 13, 2009 ive stuck it on charge now so now i play the waiting game.... Link to comment Share on other sites More sharing options...
supraspeed Posted January 13, 2009 Author Share Posted January 13, 2009 As others have said, crank pulley is the obvious suspect if all ancilleries failed. You can manually check it by hand if the car wont start.See is there is any play or any visual damage up close... Or// remove the battery, stick it on a charger overnight (you need to do this asap anyway, a good pulse charger really) and then start the car the next day. ONLY to check the crank pulley though. As others have said, if its gone that badly then it will not spin true...andy wobbles and thats the culprit and you should have it replaced by someone who knows what they are doing....! just out of interest is it a big job to replace the crank pulley? and is it just the crank pulley which needs replacing or other supporting parts? Link to comment Share on other sites More sharing options...
colsoop Posted January 13, 2009 Share Posted January 13, 2009 Are there no memebrs local to you who know what there looking for that could help you out. It could save you a few quid rather than you not knowing and spending out on the wrong part. I hope your luck improves Link to comment Share on other sites More sharing options...
supraspeed Posted January 13, 2009 Author Share Posted January 13, 2009 Are there no memebrs local to you who know what there looking for that could help you out. It could save you a few quid rather than you not knowing and spending out on the wrong part. I hope your luck improves none that i know of. i'l do a random search of people lol Link to comment Share on other sites More sharing options...
supraspeed Posted January 13, 2009 Author Share Posted January 13, 2009 charged car up to the point of starting it. checked for wobbles on pulley when blipped throttle and seems not to alter position. quite hard to see though through other moving parts.....nearly took my face off from the fan lol. Just out of interest can you see the alternator spinning or moving normally? just when i looked at that when engine is going, it doesn't seem to do anything (unless it normally just sits there motionless) Link to comment Share on other sites More sharing options...
Scooter Posted January 13, 2009 Share Posted January 13, 2009 Just out of interest can you see the alternator spinning or moving normally? just when i looked at that when engine is going, it doesn't seem to do anything (unless it normally just sits there motionless) which bit is motionless? is the small pulley wheel not spinning? Link to comment Share on other sites More sharing options...
supraspeed Posted January 13, 2009 Author Share Posted January 13, 2009 ok this is what i'm seeing. now in one of the pics with the alternator with arrow, should this be moving (flux looking bits inside alternator) the belts are moving alternator pulley fine. Now the wire coming from the alternator in 2nd pic is bit thin and worn and not sure if it looks like its working. the 3rd pic highlights the symbol next to the battery which is always on but the battery has gone off ( i assume by charging it) is this the alternator symbol? also what does this oil symbol mean in pic 4 as its lighted up now even though i topped up the oil sunday? Link to comment Share on other sites More sharing options...
Smellywelshman Posted January 13, 2009 Share Posted January 13, 2009 It means overheating cat mate (according to alot of people on here when I asked!) Those are the exact same lights that were coming on when my alt was shot! O/H cat when the car was being started from cold and all that. Things just go a tad bonkers when the alternator goes apparently... Get the charge on your battery checked out, I'll bet you'll see a figure of around 9v as the alt isn't charging your battery! Link to comment Share on other sites More sharing options...
Smellywelshman Posted January 13, 2009 Share Posted January 13, 2009 By the way, were your turbos going mental at the time everything else was going wrong? Spooling up and whistling even though you were nowhere near being on boost just before everything went dead? Link to comment Share on other sites More sharing options...
RobSheffield Posted January 13, 2009 Share Posted January 13, 2009 The oil can with a level below it means low oil. Link to comment Share on other sites More sharing options...
supraspeed Posted January 13, 2009 Author Share Posted January 13, 2009 By the way, were your turbos going mental at the time everything else was going wrong? Spooling up and whistling even though you were nowhere near being on boost just before everything went dead? i'm running single. because of the 5 speed box i havent spooled up my turbos till i get my 6spd conversion done- i havent got any cats (catalic converter if that what you meant?) as its straight through exhaust system. Link to comment Share on other sites More sharing options...
supraspeed Posted January 13, 2009 Author Share Posted January 13, 2009 ok just did a simple battery test on the alternator and looks likes its busted- must be internal as the belt drives the pully but flux doesn't move so somethings gone. car must have been purley running off the new battery all the time. time for a new alternator me thinks. Link to comment Share on other sites More sharing options...
Smellywelshman Posted January 13, 2009 Share Posted January 13, 2009 Told you so;) Be prepared for the anal shrinking price from Mr T though!!! Link to comment Share on other sites More sharing options...
Scooter Posted January 13, 2009 Share Posted January 13, 2009 Kerons and others will be selling complete na engines for £150 ish so an alternator must be available for £50 or so i'd imagine....... Link to comment Share on other sites More sharing options...
RobSheffield Posted January 13, 2009 Share Posted January 13, 2009 Id be looking at that alternator to find out why its not working, then id be panicking as to why PAS went, unless you just meant it stopped because the engine had died. Link to comment Share on other sites More sharing options...
Smellywelshman Posted January 14, 2009 Share Posted January 14, 2009 Id be looking at that alternator to find out why its not working, then id be panicking as to why PAS went, unless you just meant it stopped because the engine had died. My PAS went around 30secs before the engine died when this happened to me as well. New alt sorted everything mate. Link to comment Share on other sites More sharing options...
