Please explain how tyres work...
Bradb
Granted I know they touch the road. But with these new Kahns I getting later today.
265, 40, 18 x 2 (rears)
235, 40, 18 x 2 (front)
Is what I've been advised. Does that sound cool?
Whats the first number mean 265/235? Me confused. Is it the tyre width?
The 40 is the tyre depth between alloy and floor
18 as in inches
Sorry to be such a dolt, but I wouldn't ask if I knew the answers.
Also what kinda cost can I expect to pay on tyres of this sizing?
The 235 etc. is the width of the tyre in mm.
The 40 is the aspect ratio - basically the height of the sidewall as a percentage of the tyre width. This makes a 235/40 have a sidewall height of 235x40%=94mm.
Measurements are taken from the where the bead contacts the wheel rim.
Speed Rating - Miles/Hour - Kilometers/Hour - Typical Use
N=87 MPH, 140km/h,
P=93 MPH, 150km/h Spare Tires
Q=99 MPH, 160km/h, Winter, LT Tires
R=106 MPH, 170km/h,LT Tires
S=112 MPH, 180km/h
T=118 MPH, 190km/h
U=124 MPH, 200km/h
H=130 MPH, 210km/h, Sport Sedans
V=149 MPH, 240km/h, Sports Cars
Z=149 MPH, 240km/h and over, Sports Cars
W=168 MPH, 270km/h, Exotic Sport Cars
Y=186 MPH, 300km/h, Exotic Sport Cars
*Today, the Z-speed rating is the only speed rating that is still branded “within” the tire size, as in P225/50ZR16. All other speed ratings are shown in the tire’s service description.
Why don't you go for the Y- rated tire as you may want to do 180+ someday!
:D
Randy:D
Originally posted by Bradb
Y's it is kids.. ;:cool:
Safe I'll get the Z boots.
:conf: :( :conf:
Z- has a speed rating of only over 149mph!!
W=168 MPH, 270km/h, Exotic Sport Cars!!
Y- has a speed rating of over 186mph!!:D
When Z-speed rated tires were first introduced, they were thought to reflect the highest speed rating that would ever be required. Since that time the automotive industry has found it necessary to add W- and Y-speed ratings (indicated in the tire’s service description) to identify the tires that meet the needs of new vehicles that have extremely high, top speed capabilities.
While all Z-speed rated tires are capable of speeds of 149 mph and above, prior to the W- and Y-speed ratings were identified in the service, how far above 149 mph was not identified.
Randy:)
Why 35 at rear and 40 at front.. Its like a reverse go cart that way?
The 35 and 40 are percentages of the tyre width.
So, 265*35 gives a tyre wall height equal to 35% of 265 = 93mm.
245*40 gives a tyre wall height equal to 40% of 245 = 98mm.
Not sure how exact the measurements are, though - I thought the tyre wall heights should be the same, this working out seems to imply the fronts would be 5mm higher than the rears, but if the percentages quoted on teh sides of the tyres are rounded to the nearest multiple of 5 for presentation purposes, then they probably are the same height.
-Ian
If that is so this is how it should appear!!:p
P225/50ZR16 149mph+ 240kmph+
P225/50ZR16 91W---- 168mph---- 270kmph
P225/50ZR16 91Y 186 mph---300kmph
The Z stays where it is like the example on top but they are rated seperately on the sidewall next to the load index--W-Y etc..
Below is the tire side wall info!!:D
If you read the above thread and my previous thread you would have understood better! Z is an old speed rating that is still used today to identify High Performance tires.
The new rating is W and Y-- MAX PERFORMANCE TIRE where they have been specifically and reliably tested to the speed they mentioned 168 and 186. The Z as they have mentioned has been tested upto only 149mph the old performance rating which is specific to most brands.
Although Mc Laren may have used the Z rated tires they were made specifically for Mc Laren by Goodyear the Eagle F1/Supercar tires as original equipment in 1995. These tires in specific were tested by Goodyear for speed.
They were special tires which had very large tread blocks formed into asymmetric and directional tread designs. Since each of these vehicles uses different front and rear tire sizes, they all require four separate “corner specific” tires to give the required performance.
Hope you got this!!:)
Just a note but these speed ratings ar meant as a guide for SUSTAINED high speed runs and how offten do we get to keep up those sort of speeds on U.K. roads :devil:
The speed rating is worked out by how well the tyre disapates heat along with other things ! thus a car thats heavy may want to use a tyre with a higher speed rating !
