RobSheffield Posted October 11, 2008 Author Share Posted October 11, 2008 In that case, I suggest a Meccano set. Shurrup you! Link to comment Share on other sites More sharing options...
Ewen Posted October 11, 2008 Share Posted October 11, 2008 Shurrup you! Link to comment Share on other sites More sharing options...
steb9780 Posted October 12, 2008 Share Posted October 12, 2008 Buy a CNC miller, not cheap but you can get a decent Bridgeport for about £8k and you can do pretty much anything on it. If I could afford, I would have one, like I have at work. Brilliant machines Link to comment Share on other sites More sharing options...
Burna Posted October 13, 2008 Share Posted October 13, 2008 Why don't you buy one of the cheap lathes that people have posted and have a go at making a chess set, once you have the skills the ideas will start flowing of what you feel like making Link to comment Share on other sites More sharing options...
TRACIE_LOU Posted October 13, 2008 Share Posted October 13, 2008 Buy a CNC miller, not cheap but you can get a decent Bridgeport for about £8k and you can do pretty much anything on it. If I could afford, I would have one, like I have at work. Brilliant machines this mill is for light work only dont forget something like this will also require 3 phase power Link to comment Share on other sites More sharing options...
Scott Posted October 13, 2008 Share Posted October 13, 2008 Why don't you buy one of the cheap lathes that people have posted and have a go at making a chess set, once you have the skills the ideas will start flowing of what you feel like making Great idea. There will be a lot of hobby things you can make. The above is a good idea and you can get used to different materials by making one set copper or brass and the other set stainless or aluminium. You could even mix and match with all pawns aluminium and copper with the main pieces stainless and brass. Link to comment Share on other sites More sharing options...
RobSheffield Posted October 13, 2008 Author Share Posted October 13, 2008 Great idea. There will be a lot of hobby things you can make. The above is a good idea and you can get used to different materials by making one set copper or brass and the other set stainless or aluminium. You could even mix and match with all pawns aluminium and copper with the main pieces stainless and brass. Oh dear, you and Burna have started something there Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted October 13, 2008 Share Posted October 13, 2008 you could make a top hose adaptor to fit a coolant temp sender in. You could use square stock which would get you used to a 4 jaw chuck, you would be able to practice cutting a radius on each end (so the hose doesn't slip off) and then you could use a pedestal drill to drill the boss for the sender and then tap the hole. It is also a perfect sized job for a hobby lathe. Link to comment Share on other sites More sharing options...
TRACIE_LOU Posted October 13, 2008 Share Posted October 13, 2008 if you intend to use various materials and why not you should insure any mill /lathe has a good speed range my advice comes on the back of 20 years as a toolmaker in case your wondering Link to comment Share on other sites More sharing options...
Ewen Posted October 13, 2008 Share Posted October 13, 2008 Oh dear, you and Burna have started something there Great idea though. Link to comment Share on other sites More sharing options...
TRACIE_LOU Posted October 13, 2008 Share Posted October 13, 2008 if you have never used a lathe before i would practice with round stock to start with and remember this golden rule for a begginer always hold minimum 2 thirds of the material unless your support the other end with a running centre Link to comment Share on other sites More sharing options...
TRACIE_LOU Posted October 13, 2008 Share Posted October 13, 2008 :dyou can make anything on a lathe m8 as has been said chess pieces good practice,fruit bowls ash trays,door knobs or gear knobs dial rings heater control knobs all of which you could offer for sale here at discounted prices lol Link to comment Share on other sites More sharing options...
Burna Posted October 13, 2008 Share Posted October 13, 2008 Oh dear, you and Burna have started something there I made a set with one half out of ali and the other brass. Good luck machining the brass Tip: Wear gloves Link to comment Share on other sites More sharing options...
Scott Posted October 13, 2008 Share Posted October 13, 2008 I made a set with one half out of ali and the other brass. Good luck machining the brass Tip: Wear gloves Tip to keep limbs, wear gloves when touching cuttings but don't go near machine while its actually turning with them on Link to comment Share on other sites More sharing options...
Burna Posted October 13, 2008 Share Posted October 13, 2008 Tip to keep limbs, wear gloves when touching cuttings but don't go near machine while its actually turning with them on Lol yeah, now thats a good tip for you Rob Link to comment Share on other sites More sharing options...
bromy Posted October 13, 2008 Share Posted October 13, 2008 Buy a CNC miller, not cheap but you can get a decent Bridgeport for about £8k and you can do pretty much anything on it. If I could afford, I would have one, like I have at work. Brilliant machines Bridgeport and Fanuc suck, sell your house and buy a Mazak:p Link to comment Share on other sites More sharing options...
RobSheffield Posted October 13, 2008 Author Share Posted October 13, 2008 Oh god, we have CNC miller envy now Link to comment Share on other sites More sharing options...
bromy Posted October 13, 2008 Share Posted October 13, 2008 Oh god, we have CNC miller envy now Just posh Rob;) Link to comment Share on other sites More sharing options...
dcarrter21 Posted October 13, 2008 Share Posted October 13, 2008 Heidenhain is the only way Link to comment Share on other sites More sharing options...
snake Posted October 13, 2008 Share Posted October 13, 2008 Get a ring grinder then you can regrind brake discs;) Link to comment Share on other sites More sharing options...
Paul Posted October 13, 2008 Share Posted October 13, 2008 Eh, have I lost the plot here? I thought he was after a hobby type bit of kit rather than a full blown CNC jobbie, bit on the large size and costly for your average garage:) Link to comment Share on other sites More sharing options...
Scott Posted October 13, 2008 Share Posted October 13, 2008 Get a ring grinder then you can regrind brake discs;) Can do that on a lathe anyway. Link to comment Share on other sites More sharing options...
dcarrter21 Posted October 13, 2008 Share Posted October 13, 2008 a guy at my work has converted one of the machine mart lathes to cnc. nice and small,not to hard to program either.he brought everything off ebay. Link to comment Share on other sites More sharing options...
RobSheffield Posted October 13, 2008 Author Share Posted October 13, 2008 Eh, have I lost the plot here? I thought he was after a hobby type bit of kit rather than a full blown CNC jobbie, bit on the large size and costly for your average garage:) I am, and now its talk of milling and CNC and mortaging my house Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 13, 2008 Share Posted October 13, 2008 Buy a CNC miller, not cheap but you can get a decent Bridgeport for about £8k and you can do pretty much anything on it. If I could afford, I would have one, like I have at work. Brilliant machines If you lived nearer I'd be tempted to get one and pay you to show me how to use it Are XYZ's any good? I don't suppose I should even be CONSIDERING this, given my manual Bridgeport with a basic DRO is still a bit of a mystery, but it's so cool how a basic CNC mill or lathe can make little runs of things quite viable... Looking for a floor standing hydraulic press, used, about 50 ton capacity, and a decent UK made metal shear, about 48 inch, manual one is fine, Edwards or similar, if you ever get to hear of things like that? Link to comment Share on other sites More sharing options...
