Luka-P Posted September 5, 2008 Share Posted September 5, 2008 Anyone have a crank available? Maybe left over from a stroker conversion? Must be mint, stock, never ground or polished etc. Thanks Link to comment Share on other sites More sharing options...
Scooter Posted September 5, 2008 Share Posted September 5, 2008 I have a NA bottom end sat on a engine stand in the garage. I've yet to seperate the pistons/rods etc to check the bearings etc. Pros I think the NA crank is the same! Its not been sitting around seperate for any length of time. You'll be able to see anything you want from the block, ie all small and big end bearing shells as i remove them? + anything else that will help verify its 100% If you were happy with it, it would be cheap.... Cons Its from a 'unknown' engine, i've not heard it running It'll be a PITA to pack/post! Link to comment Share on other sites More sharing options...
Luka-P Posted September 6, 2008 Author Share Posted September 6, 2008 PM'd dude! Link to comment Share on other sites More sharing options...
Scooter Posted September 6, 2008 Share Posted September 6, 2008 some pics Link to comment Share on other sites More sharing options...
Nic Posted September 6, 2008 Share Posted September 6, 2008 I think the NA crank is the same! Yes they are the same on the 2JZGE and 2JZGTE. Link to comment Share on other sites More sharing options...
Luka-P Posted September 6, 2008 Author Share Posted September 6, 2008 Thanks Nic, great help bud! Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 8, 2008 Share Posted September 8, 2008 I've got a few available if you need one. Link to comment Share on other sites More sharing options...
Gaz Walker Posted September 8, 2008 Share Posted September 8, 2008 I've got a brand new, boxed one here from Toyota if needbe. Link to comment Share on other sites More sharing options...
