coolant in gear box :(
fizzle
well... the hose on the bottom of the rad burst off, dumping all contents on the floor and the auto box wouldnt engage, a creamy coffee coloured mix came out bottom of rad. i disconnected the rad refilled the trans fluid and all was good, no leaks etc,(minus a rad) after leavin it running for a bit checked the trans fluid and it had the same coffee coloured slime on the dipstick.....
so the coffee slime in the trans fluid mite just be excess from when it burst, i know it need a new rad already (was just checkin the gearbox/gaskets werent broken when i bypassed the rad)
this is not on my supra but on my m8's hilux. but principal will be the same!
Once an auto box has had water in it it's usually goodnight Vienna, sometime down the road. The valve block won't like it, the brake and clutch bands won't like, the bearings won't like it... I'd keep an eye open for a good used box and torque converter and flush the coolant lines and cooler when you fit it.
crikey thought you were on about the supe ! after we did all the fluids the other week too, hope it can be sorted bud c u soon
