supra_si Posted July 31, 2008 Share Posted July 31, 2008 Cars started doing this more and more often, not sure whats going on but aux belt is squeeling and in the morning the cars needing to be turned over a few times before starting. could it be a case of not recharging the battery properly due to belt slippage. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 31, 2008 Share Posted July 31, 2008 Well if its turning over the battery's probably ok. As for the squealing just change the belt, cheap and easy to do Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 31, 2008 Share Posted July 31, 2008 Has the crank damper come apart? That'll cause belt slippage and low charging. Quote Link to comment Share on other sites More sharing options...
supra_si Posted July 31, 2008 Author Share Posted July 31, 2008 Has the crank damper come apart? That'll cause belt slippage and low charging. whats one of those?? i think i need a belt change to be honest. its basically just a click at first and sometimes second. then it will just start as normal, Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 31, 2008 Share Posted July 31, 2008 Clicking is usually caused by burnt out contacts in the starter motor itself, you can buy repair kits, or I can recondition the starter if you can't get it done locally. Do a search, there's loads of info on crank damper issues. I have a new one on the shelf if you need it. Quote Link to comment Share on other sites More sharing options...
Missile Posted July 31, 2008 Share Posted July 31, 2008 My crank pully came apart. It squeeled every now and then before I replaced it, Espesially if you tuned on the air con. Just for your info incase that helps. Quote Link to comment Share on other sites More sharing options...
supra_si Posted July 31, 2008 Author Share Posted July 31, 2008 hmm well il start with a belt change as i can get some mates to do that for me for beer money. i will investigate it if that does not work Quote Link to comment Share on other sites More sharing options...
