Guest Nizam Posted June 30, 2008 Share Posted June 30, 2008 EGT,AIR FUEL RATIO AND FUEL PRESSURE do i really need to get fuel prussure gauges? is this important? i need help if i do need it or not please let me know cheers Link to comment Share on other sites More sharing options...
Jake Posted June 30, 2008 Share Posted June 30, 2008 Sorry, what is your question? Is it "Do I need a fuel pressure gauge?"? Is so, the answer is no. Link to comment Share on other sites More sharing options...
Thorin Posted June 30, 2008 Share Posted June 30, 2008 You don't need any of them, if you did Toyota would have fitted them. They are all nice to have though, with AFR being the most useful IMO. Link to comment Share on other sites More sharing options...
Guest Nizam Posted June 30, 2008 Share Posted June 30, 2008 just need afr? what about egt? Link to comment Share on other sites More sharing options...
Guest Nizam Posted June 30, 2008 Share Posted June 30, 2008 please let me know. today im going to buy it Link to comment Share on other sites More sharing options...
Gaz6002 Posted June 30, 2008 Share Posted June 30, 2008 What spec is your Supra? Is it a TT? Link to comment Share on other sites More sharing options...
Thorin Posted June 30, 2008 Share Posted June 30, 2008 just need afr? what about egt? If you're fitting an AFR I wouldn't bother with the EGT gauge personally. EGT is a crude way of measuring if you're running lean. Link to comment Share on other sites More sharing options...
Guest Nizam Posted June 30, 2008 Share Posted June 30, 2008 does it happened to you? Link to comment Share on other sites More sharing options...
Guest Nizam Posted June 30, 2008 Share Posted June 30, 2008 yes tt mate Link to comment Share on other sites More sharing options...
Thorin Posted June 30, 2008 Share Posted June 30, 2008 does it happened to you? Does what happen to me? Link to comment Share on other sites More sharing options...
Guest Nizam Posted June 30, 2008 Share Posted June 30, 2008 did u had egt gauges before mate? Link to comment Share on other sites More sharing options...
Guest Nizam Posted June 30, 2008 Share Posted June 30, 2008 most important use AFR that it? Link to comment Share on other sites More sharing options...
Thorin Posted June 30, 2008 Share Posted June 30, 2008 No, I don't have an EGT gauge. Link to comment Share on other sites More sharing options...
Guest Nizam Posted June 30, 2008 Share Posted June 30, 2008 ok thank you for telling me mate. all i need to get AFR? Link to comment Share on other sites More sharing options...
Gaz6002 Posted June 30, 2008 Share Posted June 30, 2008 yes tt mate What modifications have you done to it? Why do you feel you need gauges? Link to comment Share on other sites More sharing options...
JustGav Posted June 30, 2008 Share Posted June 30, 2008 Don't forget the flux capacitor monitoring unit either. Link to comment Share on other sites More sharing options...
Gaz6002 Posted June 30, 2008 Share Posted June 30, 2008 Don't forget the flux capacitor monitoring unit either. That was close! Almost forgot about that!! Link to comment Share on other sites More sharing options...
Jake Posted June 30, 2008 Share Posted June 30, 2008 Does what happen to me?Does you replied thread and but then wish that you had bothered!!!? Link to comment Share on other sites More sharing options...
Thorin Posted June 30, 2008 Share Posted June 30, 2008 Does you replied thread and but then wish that you had bothered!!!? Are you interesting? Link to comment Share on other sites More sharing options...
Gaz6002 Posted June 30, 2008 Share Posted June 30, 2008 Are you interesting? I'm interesting! See? Link to comment Share on other sites More sharing options...
Jake Posted June 30, 2008 Share Posted June 30, 2008 Are you interesting? I have my moments. errr, are you trying to 'groom' me again? Link to comment Share on other sites More sharing options...
Guest Nizam Posted June 30, 2008 Share Posted June 30, 2008 Well my car will be upgrade 400 -420bhp BPU. so i need to get AFR gauges,and decat pipe and Greddy BCC. gauges will be good for me mate Link to comment Share on other sites More sharing options...
Gaz6002 Posted June 30, 2008 Share Posted June 30, 2008 Well my car will be upgrade 400 -420bhp BPU. so i need to get AFR gauges,and decat pipe and Greddy BCC. gauges will be good for me mate In which case: I'd get AFR, boost, oil temp and pressure and water temp. Link to comment Share on other sites More sharing options...
JustGav Posted June 30, 2008 Share Posted June 30, 2008 Okay, I'm going to go out on a limb here and say that you don't fully understand car tuning.... (Not sure where I get that impression from), the best bit of advice I can give you is to go see a KNOWN and RECOGNIZED tuner and see what they suggest. Just by the fact you don't know what gauges you want or why, it is better off left to those that do. Link to comment Share on other sites More sharing options...
Gaz6002 Posted June 30, 2008 Share Posted June 30, 2008 Okay, I'm going to go out on a limb here and say that you don't fully understand car tuning.... (Not sure where I get that impression from), the best bit of advice I can give you is to go see a KNOWN and RECOGNIZED tuner and see what they suggest. Just by the fact you don't know what gauges you want or why, it is better off left to those that do. It doesn't matter what they do... they look nice!! Link to comment Share on other sites More sharing options...
