SteveR Posted June 24, 2008 Share Posted June 24, 2008 Just out of curiousity, before I stick a quieter one on it and get the watsegate plumbled through it so I'm inside the 'Ring/track day noise limits. Results... STATIC (1m @ 45degrees): - idle: 84dB - 5,000 rpm: 95dB Drive-by (20m @ 90 degrees): - WOT (wastegate open): 97dB!!! Doh! 97dB measured from 20m away is just silly loud; approx 123dB equivalent at 1m if I've done the calcs right. Quote Link to comment Share on other sites More sharing options...
Muffleman Posted June 24, 2008 Share Posted June 24, 2008 Nuts Quote Link to comment Share on other sites More sharing options...
miko_supra Posted June 24, 2008 Share Posted June 24, 2008 123db!? Quote Link to comment Share on other sites More sharing options...
Pig Posted June 24, 2008 Share Posted June 24, 2008 What exhaust are you running? That seems a very low static reading. Quote Link to comment Share on other sites More sharing options...
lockys96 Posted June 24, 2008 Share Posted June 24, 2008 seems a low 5,000rpm reading too Quote Link to comment Share on other sites More sharing options...
SteveR Posted June 24, 2008 Author Share Posted June 24, 2008 What exhaust are you running? That seems a very low static reading. It doesn't sound low when you're stood next to it! HKS Carbon/Titanium. 84dB is pretty loud; on par with a diesel truck driving past at 40mph, apparently. Quote Link to comment Share on other sites More sharing options...
bignum Posted June 24, 2008 Share Posted June 24, 2008 Also all uk circuits measure @ 50cm static Quote Link to comment Share on other sites More sharing options...
lockys96 Posted June 24, 2008 Share Posted June 24, 2008 that will be why then Quote Link to comment Share on other sites More sharing options...
Pig Posted June 25, 2008 Share Posted June 25, 2008 It doesn't sound low when you're stood next to it! HKS Carbon/Titanium. 84dB is pretty loud; on par with a diesel truck driving past at 40mph, apparently. Thats the same as me and im WAY over. what settings have you got it on? And are you having someone hold the tester or are you leaving it on the floor. Jon Which size pipe have you got? 3 or 4 inch? Quote Link to comment Share on other sites More sharing options...
SteveR Posted June 25, 2008 Author Share Posted June 25, 2008 Thats the same as me and im WAY over. what settings have you got it on? And are you having someone hold the tester or are you leaving it on the floor. Jon Which size pipe have you got? 3 or 4 inch? Instant reading, average over a second and peak; held by a friend at a measured 1m and a guessed 45degrees. All the numbers match up when the revs are held for a few seconds. Are you measuring at 50cm as that's the distance bignum says UK tracks use? The reading would be significantly higher at half the distance. I only used 1m as it's what the 'Ring uses, and that's where I'll be next... Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 25, 2008 Share Posted June 25, 2008 Also all uk circuits measure @ 50cm static They also measure drive by though, passing static is easy, passing drive by is the killer. Quote Link to comment Share on other sites More sharing options...
