Blackie Posted May 21, 2008 Share Posted May 21, 2008 I noticed my new Do-luck has no conventional mounting points and i'm guessing my Veilside hasent ether. How are they fitted/removed? Quote Link to comment Share on other sites More sharing options...
marcAB10 Posted May 21, 2008 Share Posted May 21, 2008 velcro Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 21, 2008 Share Posted May 21, 2008 With a hammer;) Quote Link to comment Share on other sites More sharing options...
Blackie Posted May 21, 2008 Author Share Posted May 21, 2008 Silly answers are not so much fun when its my thread Quote Link to comment Share on other sites More sharing options...
marcAB10 Posted May 21, 2008 Share Posted May 21, 2008 (edited) i'm guessing 'they' drill new holes on the new bumper and use the original screws? Edited May 21, 2008 by marcAB10 (see edit history) Quote Link to comment Share on other sites More sharing options...
Homer Posted May 21, 2008 Share Posted May 21, 2008 They are normally connected using the stock mounting points. Headlights out to get to the front bolts on the sides, then remove wheel arch inner trim, turn the wheel to get to the ones on the ends. The ones at the front can be got to if you remove the weather seal on the top on the bumper. The Do-luck should use the same locations to connect it. Quote Link to comment Share on other sites More sharing options...
Blackie Posted May 21, 2008 Author Share Posted May 21, 2008 They are normally connected using the stock mounting points. Headlights out to get to the front bolts on the sides, then remove wheel arch inner trim, turb wheel to get to the ones on the ends. The ones at the front can be got to if you remove the weather seal on the top on the bumper. The Do-luck should use the same locations to connect it. Brilliant, Thanks very much. Very helpfull Quote Link to comment Share on other sites More sharing options...
