UK specs or J-specs for hybrids??
mikeyb10supra
I would still love to have this proved again but the j-specs have considerably larger internals.
I have also been told that the UK spec turbos have less capacity to be honed out to take bigger hybrids, but thats anecdotal and I have no proof.
There are pictures on the forum somewhere of the internals which show the differences.
JB
Which I believe you posted didn't you?? Going back a few years now!
well yes, but then it would have looked rude if I didnt post a link to my own post and Im scared of the search system, it brings back too many memories ;)
Since then I dont remember seeing anybody confirm that its true and done the same comparison so it would be good to actually have somebody double check it one day.
I think the consensus in the US is that J spec turbos are better, due to the shaft diameter, case wise, either can be machined, so there is little in it, however both J spec and UK turbos seem to last a similar mileage.
wont the shaft be changed as well though when the hybrids are built??
My thinking behind this is that the UK's have a larger exhaust housing and would possibly make a better turbo to build hybrids with
im still convinced despite the speculation and people not liking them, there is potential with hybrids
Edited by mikeyb10supra (see edit history)
Shaft stays the same, due to core size, but if you chuck enough money at it then anythings possible, need to stick mine on a RR to see what its making;) made 370 and 390ftlbs at only 5,000RPM at 1.1 bar but aborted run.
thats a good power figure given the low settings. How do you find the response compared to BPU levels.
I think when I take the plunge I will be using meth as well to maximise the high boost setting ie 1.1-1.4bar are you using meth with your setup as well? not sure to go pure meth given the high boost of a high concentration mix
the specs might not be right. Didn't the jspec supra use CT20a (or something similar)
From what I gather, the J Spec turbos are CT20. When the CT20B was released (which is a more advanced turbo, possibly bigger too) the old one started to be called a CT20A, just to help confuse us. ;)
When I bought my Supra, it came with an invoice for a couple of remanufactured turbos. The part number that was fitted was CT20R. The R suffix in this case seems to point to the round turbine housing inlet. Seems to be a pretty rare feature in a turbo.
Here's some other data that I found. This is probably just going to confuse the matter because the numbers don't quite match with the documents above, but it may help someone here. I forgot to note the source of the data. Chances are it was on here somewhere.
Manufacturer Toyota (Hitachi)
Type CT-20 (PN: 17201-46020 (Front), 17208-46020 (Rear)
Turbine size (Outlet diameter) 48mm
Turbine size (Inlet diameter) 59.8mm
Turbine blade count 10
Turbine material Ceramic
Turbine housing Inlet (ID) 36mm
Turbine housing Outlet (ID) 50.1mm
Turbine shaft Diameter 10mm
Turbine housing A/R .35
Compressor size (Inlet diameter) 37mm
Compressor size (Outlet diameter) 62mm
Compressor blade count 10
Compressor material Aluminium
Compressor housing Inlet (ID) 49.8mm
Compressor housing Outlet (ID) 32.4mm
Compressor housing A/R .36
*Wastegate size (ID) 26mm
Actuator spring rate 10 psi
Bearing ID 10.05mm
Bearing OD 15.9mm
Bearing width 9mm
Bearing material Bronze
Bearing oiling holes (per bearing) 6
Manufacturer Toyota (Hitachi) Export Specification (Steel Turbines)
Type CT-12B (PN: ? (Front), ? (Rear)
Turbine size (Outlet diameter) 44mm
Turbine size (Inlet diameter) 52mm
Turbine blade count 9
Turbine material Steel
Turbine shaft Diameter 7.5mm
Turbine housing A/R
Compressor size (Inlet diameter) 39mm
Compressor size (Outlet diameter) 58mm
*Wastegate size (ID) 30mm
Bearing ID 8.53mm
Bearing OD 13.55mm
Bearing width 9mm
  • 2 weeks later...
After having a chat with the guys from Universal Turbos at Japfest (they did the fitting of my current turbos, very helpful too) it turns out that the R in CT20R simply stands for "Remanufactured". Turns out I was chatting b*****s before.
