Chris Wilson Posted May 1, 2008 Share Posted May 1, 2008 Really hope this is all taken as good helpful advice...as that's how it's all meant. We want to see the Supra's running at the front of the TA events You mean as a course car? (I'll get my coat.....) Quote Link to comment Share on other sites More sharing options...
GazB Posted May 1, 2008 Share Posted May 1, 2008 Well explained Tony, that was a pleasure to read and digest. Quote Link to comment Share on other sites More sharing options...
TLicense Posted May 1, 2008 Share Posted May 1, 2008 Really hope this is all taken as good helpful advice...as that's how it's all meant. We want to see the Supra's running at the front of the TA events Absolutely. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted May 1, 2008 Share Posted May 1, 2008 Well explained Tony, that was a pleasure to read and digest. Indeedy, much appreciated, more info the better. Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 2, 2008 Share Posted May 2, 2008 So in conclusion - bin the wing, set up the suspension, and invest a grand in polishing the nut behind the wheel - and see the seconds fall off the laptimes -Ian Quote Link to comment Share on other sites More sharing options...
GazB Posted May 2, 2008 Share Posted May 2, 2008 In 'simple terms' i think you are spot on with that conclusion Ian. All in one sentence as well Quote Link to comment Share on other sites More sharing options...
b.weeks Posted May 2, 2008 Author Share Posted May 2, 2008 Fancy having a word with Patrick to see if we can use his wind tunnel? Now that would be ideal :-) Anything else to be honest is guess work - although some track time just changing wings etc. would also help to see how they affect time. Quote Link to comment Share on other sites More sharing options...
b.weeks Posted May 2, 2008 Author Share Posted May 2, 2008 Toyota use a lower wing than the APR on there race car. Maybe we should just source all those parts :-) (if possible) EDIT Some good pictures here: http://www.autoblog.com/photos/denso-sard-supra-hv-r/279227/ and only aero parts from SARD (http://en.wikipedia.org/wiki/SARD) I can find are here http://www.sard.co.jp/product/exteria/index.html so maybe not commercially available replica kits? Quote Link to comment Share on other sites More sharing options...
TLicense Posted May 2, 2008 Share Posted May 2, 2008 Now that would be ideal :-) Anything else to be honest is guess work - although some track time just changing wings etc. would also help to see how they affect time. lol, not likely I'm afraid. Any F1 team worth it's salt is using every wind tunnel it can get it's hands on 100% of the available time. If you go to a decent customer wind tunnel, then you would first need to build a wind tunnel model, which can set you back around £100K in parts / materials alone for a baseline model and without electronic control equipment, (Factor in around £100K for that) then you would need to pay for tunnel time, which is quite cheap in comparison at about £350 / hour. A full development programme for would probably take 3 - 4 months of 40 hour weeks.... Plus on top of that, I've not worked at Williams for two years, so in all likelihood, Patrick isn't going to be too open to requests. That is no BS though, it really is that expensive. Even if you take a car to Mira and use the full size tunnel there, it's ridiculously expensive and you then have the cost of making full sized components to test (which are obviously a lot more expensive than 50% scaled bits - which is why F1 teams always test at scale) I think your best bet is to concentrate on track testing. At lest that way you're getting mileage under yoru belt. Try to keep things as simple as possible, and you won't go far wrong. Good luck with it mate! Quote Link to comment Share on other sites More sharing options...
SteveL Posted May 3, 2008 Share Posted May 3, 2008 Only just seen this, thanks guys for all your comments and advice. Funnily enough my wing has recently come off as I can't get my cover over the car when its on! We'll have to do some testing as Paul says, and I must admit the comments on seat time are probably the easiest and most cost effective way of getting the cars to go faster. ... anyone want a nice big APR wing ? Quote Link to comment Share on other sites More sharing options...
and1c Posted May 4, 2008 Share Posted May 4, 2008 Great post Tony Very informative indeed..... Quote Link to comment Share on other sites More sharing options...
