gavin.starr Posted April 20, 2008 Share Posted April 20, 2008 has any one got any pictures of what the standard bov looks like on a j-speck twin turbo and where it is located in the engine bay as i want to remove it and fit my new one cheers gav Link to comment Share on other sites More sharing options...
Pixelfill Posted April 20, 2008 Share Posted April 20, 2008 The round thingy with 3 hoses coming off it. You'll need to block off one of the hoses when you put your aftermarket one on. (attachment) The blue hoses on my old BoV http://www.mkivsupra.net/vbb/vbpicgallery.php?do=big&p=157 are the ones that you use on the aftermarket replacement. Hope this helps Mike Link to comment Share on other sites More sharing options...
gavin.starr Posted April 20, 2008 Author Share Posted April 20, 2008 what bov have you got on there. ive got a blitz one thats pretty good it was located between the intercooler pipe and the battery but i had to remove it when i put my new intercooler on do you recon ill be able to intergrate it into that space or is there going to be to much bodging to be done. Link to comment Share on other sites More sharing options...
AgtX80 Posted April 20, 2008 Share Posted April 20, 2008 I just bought the HKS SSQV, i think the ones made specifically for the supra replace the stock one on top of the engine & the generic ones go in the place yours is by making a hole & welding a flange on? Link to comment Share on other sites More sharing options...
Pixelfill Posted April 20, 2008 Share Posted April 20, 2008 My old bov was a Sard R2D2 (YES REALLY), and it's not clear from that photo but it just connected by the two blue hoses, the reason it is over there is that there is a bracket that mounts the Bov on the suspension struts, so it's just the angle of the photo that makes it look more complicated than it is. I'll se if I can find a better picture, I've replaced it now with a HQS SSQV, as the SARD was filling up with oil, and jamming Mike Link to comment Share on other sites More sharing options...
Pixelfill Posted April 20, 2008 Share Posted April 20, 2008 better picture of how the SARD was attached. Mike Link to comment Share on other sites More sharing options...
AgtX80 Posted April 20, 2008 Share Posted April 20, 2008 Found this photo of the hks one installed. http://www.od-dg330.de/gross/131_3112.jpg I take it that its not actually attatched to the engine, just suspended by the hoses? Link to comment Share on other sites More sharing options...
gavin.starr Posted April 20, 2008 Author Share Posted April 20, 2008 so i take it you blank this pipe off Link to comment Share on other sites More sharing options...
Nic Posted April 20, 2008 Share Posted April 20, 2008 This is how the Blitz BOV kit fits on the Supra, don't think you can buy the fitting kit separately though. Your best bet would be to buy a flange and weld onto the IC hard pipe, either before or after the FMIC. Link to comment Share on other sites More sharing options...
gavin.starr Posted April 22, 2008 Author Share Posted April 22, 2008 hi nic where can you buy that lower flange pipe from as i could do with one Link to comment Share on other sites More sharing options...
steb9780 Posted April 23, 2008 Share Posted April 23, 2008 hi nic where can you buy that lower flange pipe from as i could do with one Probably from Nic Link to comment Share on other sites More sharing options...
supraGZaerotop Posted August 2, 2008 Share Posted August 2, 2008 hi nic where can you buy that lower flange pipe from as i could do with one i would like to know this also, anyone Link to comment Share on other sites More sharing options...
Jim_1979 Posted August 2, 2008 Share Posted August 2, 2008 I have a the exact Blitz Bov with a much bigger aperture on a flange type thing. I'm looking to get it welded onto my FMIC piping. Would live to get the Supra specific fitting kit if possible? Surely it is as you can buy replacement parts etc for the bov. Anyone? Link to comment Share on other sites More sharing options...
supra_si Posted August 2, 2008 Share Posted August 2, 2008 the hks actually has a mounting bracket and is not free floating. Link to comment Share on other sites More sharing options...
Jim_1979 Posted August 2, 2008 Share Posted August 2, 2008 (edited) I want the blitz mounting kit!! I have something similar to this that I bought from ebay... http://www.blitz-uk.co.uk/ProductItem-355.aspx Anyone know the diameter of the connecting hose? Not the little vacum one. Edited August 2, 2008 by Jim_1979 (see edit history) Link to comment Share on other sites More sharing options...
supra_si Posted August 2, 2008 Share Posted August 2, 2008 ahh you bought the weld on flange Link to comment Share on other sites More sharing options...
suprattgaz Posted August 2, 2008 Share Posted August 2, 2008 Found this photo of the hks one installed. http://www.od-dg330.de/gross/131_3112.jpg I take it that its not actually attatched to the engine, just suspended by the hoses? Is there any reason as to why the pipe length for the HKS BOV is always far too long? I have seen so many installed and the small pipe is always too long and wrapped up around the bay, as in this shot. I cut mine to length to fit it - is that wrong? Link to comment Share on other sites More sharing options...
Jim_1979 Posted August 2, 2008 Share Posted August 2, 2008 ahh you bought the weld on flange Yeah, will hopefully get it welded onto my FMIC piping soon as! Link to comment Share on other sites More sharing options...
supra_si Posted August 2, 2008 Share Posted August 2, 2008 Is there any reason as to why the pipe length for the HKS BOV is always far too long? I have seen so many installed and the small pipe is always too long and wrapped up around the bay, as in this shot. I cut mine to length to fit it - is that wrong? i beleive its that long as it also fits the impreza and it needs that length to get aorund the engine bay, i cut mine down to a nice short length as have many others. Link to comment Share on other sites More sharing options...
Guest Nizam Posted August 3, 2008 Share Posted August 3, 2008 i got blizt bov while ago but i hav't fit it yet. can i ask you will be the best put bov on intercooler pipe? Link to comment Share on other sites More sharing options...
supraGZaerotop Posted August 3, 2008 Share Posted August 3, 2008 hi all, ive just bought this, are they any good, also do i have to take off standard valve, i would like to get ahold of the blitz pipe that goes in the stock position but cannot find them anywhere. Link to comment Share on other sites More sharing options...
supraGZaerotop Posted August 3, 2008 Share Posted August 3, 2008 can you run two bovs, ie, one in the standard location (being ether standard bov or hks sqv) and one on the throttle pipe(blitz duel drive), wonder what it would sound like altho i bet you have to really give it the beans to activate the both of them. Link to comment Share on other sites More sharing options...
Nic Posted August 3, 2008 Share Posted August 3, 2008 You can either run it with the standard valve or remove and block off the standard BOV. Link to comment Share on other sites More sharing options...
supraGZaerotop Posted August 3, 2008 Share Posted August 3, 2008 You can either run it with the standard valve or remove and block off the standard BOV. hi nic, how old is this type of hks, Link to comment Share on other sites More sharing options...
Jim_1979 Posted August 3, 2008 Share Posted August 3, 2008 Not the last type, but the one before it if I'm right in thinking? Link to comment Share on other sites More sharing options...
