Supra-Brett Posted March 1, 2008 Share Posted March 1, 2008 Hi all Just bought a set of used J spec brakes from Holeshot complete with Chris Wilson pads. The plan was to clean them up, paint them silver, refurb the seals etc and then replace my existing ones. The pics as i bought them are below Today i cleaned up one of the calipers with a drill wire brush attachment. Now they look a lot better Im going to paint it with silver smooth finish hammerite tonight but after that i will need to get hold of a refurb kit from somewhere. Ive seen the excellent guide to refurbing jspec brakes on here, but the question i have is - How much is a refurb kit and where do i get one from ? Ive also seen posts that mention shim kits. What are these ? Link to comment Share on other sites More sharing options...
markssupra Posted March 1, 2008 Share Posted March 1, 2008 Steve Manley is where you get the refurb kit. 01865 291333 Inchcape Toyota. Will cost about £66 for fronts and rear kits. Link to comment Share on other sites More sharing options...
Supra-Brett Posted March 1, 2008 Author Share Posted March 1, 2008 Steve Manley is where you get the refurb kit. 01865 291333 Inchcape Toyota. Will cost about £66 for fronts and rear kits. £66 seems a bit steep. I thought that it only comprised of 3 x rubber seals and 1 x wire fastener (therefore 12 bits of rubber and 4 x wires). Is this correct ? Link to comment Share on other sites More sharing options...
Nic Posted March 1, 2008 Share Posted March 1, 2008 £66 seems a bit steep. I thought that it only comprised of 3 x rubber seals and 1 x wire fastener (therefore 12 bits of rubber and 4 x wires). Is this correct ? £66 is steep, if you can wait a few weeks I can do quite a bit cheaper. Shim kit fits behind the pads, it prevent the brakes from squealing. Link to comment Share on other sites More sharing options...
monkey3 Posted March 1, 2008 Share Posted March 1, 2008 How much did you pay for them out of interest? Link to comment Share on other sites More sharing options...
Supra-Brett Posted March 1, 2008 Author Share Posted March 1, 2008 How much did you pay for them out of interest? £50 or front calipers Chris Wilson pads and disks, and rear calipers with Chris wilson Pads (no discs) Link to comment Share on other sites More sharing options...
Supra-Brett Posted March 1, 2008 Author Share Posted March 1, 2008 £66 is steep, if you can wait a few weeks I can do quite a bit cheaper. Shim kit fits behind the pads, it prevent the brakes from squealing. Yep, i can wait im in no rush Link to comment Share on other sites More sharing options...
Supra-Brett Posted March 10, 2008 Author Share Posted March 10, 2008 Ive now painted the calipers (pics to follow), and have removed the first piston. Removing it was a nightmare. It wouldnt budge when i pulled it with plyers from the front, so in the end, i had to insert a screwdriver into the hole at the back where the brake cable attaches and push the piston out. This was very hard also. Inside the piston was clean but the fluid was black. Is this normal ? Or must dust have got past the seal over the years ? Then i tried to remove the second piston by pulling it with plyers from the front. The second one wont budge at all, and there is no hole at the back of it with which to push it from the back. Any advice on how to get it out ? Link to comment Share on other sites More sharing options...
Guest Jason-B Posted March 10, 2008 Share Posted March 10, 2008 Ive now painted the calipers (pics to follow), and have removed the first piston. Removing it was a nightmare. It wouldnt budge when i pulled it with plyers from the front, so in the end, i had to insert a screwdriver into the hole at the back where the brake cable attaches and push the piston out. This was very hard also. Inside the piston was clean but the fluid was black. Is this normal ? Or must dust have got past the seal over the years ? Then i tried to remove the second piston by pulling it with plyers from the front. The second one wont budge at all, and there is no hole at the back of it with which to push it from the back. Any advice on how to get it out ? Heat and/or leave to soak in penetrating fluid overnight. Loctite freeze and release worked on my calipers for me Link to comment Share on other sites More sharing options...
RobSheffield Posted March 10, 2008 Share Posted March 10, 2008 Is pulling with pliers the correct way of removing as caliper? The brakes are possibly the most important part of your car dude, do it right or get someone who can! Link to comment Share on other sites More sharing options...
Supra-Brett Posted March 10, 2008 Author Share Posted March 10, 2008 Is pulling with pliers the correct way of removing as caliper? The brakes are possibly the most important part of your car dude, do it right or get someone who can! Not sure what else to use. A mechanic i know said just use plyers on the exposed bit of the caliper and pull, but not ever having done it before im not sure just how much pressure is needed Link to comment Share on other sites More sharing options...
