marcAB10 Posted February 20, 2008 Share Posted February 20, 2008 OK guys I mentioned in a previous thread that a house tile landed on my windscreen and left loads of scratches across the pasenger side.. So I decided to get a new windscreen, my parents aranged it (lame, I know ) through my insurance as my mums two week old mini needed a new windscreen aswell anyway I had it done today at my dads work and he drove it back to my flat at 4:30 (they said it would be absolutly fine as this was over an hour and a half since they finished it), my problem is that the top corners are not stuck down properly (the little rubber bits that actually touch the paint) I phoned them up and they said that they would come out tomorrow and try and fix it with a heat gun if they can.. They used my original seals which I'm pretty miffed at because I was never told about this and would have easily waited longer for them to source new ones.. So the advice I need is A. With the seal not stuck properly, and I doubt the heat gun will work as the rubber is a little worn down, if it rains can water run down and damage anything ( its sealed under the rubber so I know its water tight) but its sort of the 'flap' that sticks to the bodywork, so water could get in between the seal and the rest of the flap? (very hard to explain, I hope you lot will understand what I'm going on about ) B. I will definatly be getting the whole thing done again with new seal so does anyone know where I can source this quickly(the new rubber seal) as I don't want to wait while they source it with the rubber the way it is? I will try and post pics tomorrow when its light in case knowbody knows what I'm going on about lol Link to comment Share on other sites More sharing options...
Supra-Brett Posted February 20, 2008 Share Posted February 20, 2008 I would get then to come back and replace the screen with a new seal. I cant believe they would leave it like that. When they do it, make sure the lazy sods dry any moisture thats got in the gaps between now and the fitting date. Link to comment Share on other sites More sharing options...
Havard Posted February 20, 2008 Share Posted February 20, 2008 Sounds like a sh!t job to me! Who did the work? H. Link to comment Share on other sites More sharing options...
marcAB10 Posted February 20, 2008 Author Share Posted February 20, 2008 its the RAC up in aberdeen, they rest of the work does look spot on but i'm really p*ssed that they didn't tell me they weren't using a new seal!! i suppose its partly my fault for assuming.. the guy seemed really nice and appologetic on the phone tho.. Link to comment Share on other sites More sharing options...
marcAB10 Posted February 20, 2008 Author Share Posted February 20, 2008 anyone know where i can get this rubber seal Link to comment Share on other sites More sharing options...
AndyT Posted February 20, 2008 Share Posted February 20, 2008 anyone know where i can get this rubber seal Nic does them and Whifbitz is doing a deal on heated screens at the mo. £180. Link to comment Share on other sites More sharing options...
marcAB10 Posted February 20, 2008 Author Share Posted February 20, 2008 cheers mate i'll look in to both them. Link to comment Share on other sites More sharing options...
rxv8 Posted February 20, 2008 Share Posted February 20, 2008 im a windsheild fitter...personally i would get it taken out again and re done,BUT dont use an original trim,as they have a tendancy as you have pointed out for the corners to come up at the edge,same as skylines and mr2s...get them to bring thin flex and thick flex,which is a universal trim...which instead of sitting in side the window apperture,will sit about 2mm over the edge,which gives a much neater apperance is softer rubber so the corners dont pull up and looks 200 times better when the job is done...i have fitted a fair few,but thats just my opinion... Link to comment Share on other sites More sharing options...
marcAB10 Posted February 20, 2008 Author Share Posted February 20, 2008 thats great advice, i will definatly mention this to them cheers mate Link to comment Share on other sites More sharing options...
Pete Posted February 20, 2008 Share Posted February 20, 2008 I thought the original rubbers were like rocking horse poo and supposedly the original ones discontinued? I've heard they're horribly expensive and maybe why the RAC didn't choose to fit one. Sometimes they use Ford Transit ones instead (nasty). The problem is that they can trap water and cause corrosion whilst rubbing. Link to comment Share on other sites More sharing options...
