Guest daz 6576 Posted January 31, 2008 Share Posted January 31, 2008 i am changing the turbos on a tt auto j-spec. it already has a fcd and a sld fitted to the ecu and a boost controller does it have to be re-mapped and if so why Link to comment Share on other sites More sharing options...
colsoop Posted January 31, 2008 Share Posted January 31, 2008 What are you changing them with ? Link to comment Share on other sites More sharing options...
miko_supra Posted January 31, 2008 Share Posted January 31, 2008 you going single or what? Link to comment Share on other sites More sharing options...
Guest daz 6576 Posted January 31, 2008 Share Posted January 31, 2008 yea its having a single on it Link to comment Share on other sites More sharing options...
colsoop Posted January 31, 2008 Share Posted January 31, 2008 You need to give us the info fella. There are lots of turbos out there ! are all supporting mods in place, injectors, heat managment etc etc. Link to comment Share on other sites More sharing options...
Guest daz 6576 Posted January 31, 2008 Share Posted January 31, 2008 my turbos are on the way out so i want to put a single turbo on it. i want about 500bhp. the car already has a fmic, koyo rad, bov,plugs.ect what turbo is best and were can i get it for a good price Link to comment Share on other sites More sharing options...
TrickTT Posted January 31, 2008 Share Posted January 31, 2008 If you're fitting anything other than standard turbos, the pressure/volume of airflow will be different which alters the fuel requirements of the engine. So yes, you will need to remap the fuel injection at a minimum and possibly the ignition as well depending on what spec you're going for. Link to comment Share on other sites More sharing options...
Guest daz 6576 Posted January 31, 2008 Share Posted January 31, 2008 is the garrett t61 a good one to go for Link to comment Share on other sites More sharing options...
colsoop Posted January 31, 2008 Share Posted January 31, 2008 Your best bet would be to get a phr or boostlogic turbo kit. Check the traders section. You will also need at a minimum bigger injectors) + something to control them. Have a search there is a detailed list of whats required. Link to comment Share on other sites More sharing options...
RobSheffield Posted January 31, 2008 Share Posted January 31, 2008 I would recommend a search before 'lobbing a turbo on' and hoping for the best. Link to comment Share on other sites More sharing options...
Guest yoshi_v300 Posted January 31, 2008 Share Posted January 31, 2008 Aren't turbo kits the best way to go? Expensive, yes, but an HKS kit I presume has all the correct sized wastegate, manifold etc. Link to comment Share on other sites More sharing options...
gaz1 Posted January 31, 2008 Share Posted January 31, 2008 Aren't turbo kits the best way to go? Expensive, yes, but an HKS kit I presume has all the correct sized wastegate, manifold etc. correct, go for the complete kit, then a fuel kit, then a standalone ecu, then start grinning even with an empty wallet Link to comment Share on other sites More sharing options...
Lbm Posted January 31, 2008 Share Posted January 31, 2008 I would recommend a search before 'lobbing a turbo on' and hoping for the best. Link to comment Share on other sites More sharing options...
Nic Posted February 1, 2008 Share Posted February 1, 2008 my turbos are on the way out so i want to put a single turbo on it. i want about 500bhp. the car already has a fmic, koyo rad, bov,plugs.ect what turbo is best and were can i get it for a good price What is your budget for the complete install? The price of the turbo is a very small part of the overall cost. Link to comment Share on other sites More sharing options...
Guest yoshi_v300 Posted February 1, 2008 Share Posted February 1, 2008 Just as a side point, I know stock twins can push 450hp if pushed and your setup seems 400hp+ already. Do you really have application for the magic 500hp or is it willy waving chit? I guess the 550hp turbo kit from HKS is about right for circuit use, as anything above that will have huge lag. It's still laggy though compared to stock twins. Link to comment Share on other sites More sharing options...
hiten55 Posted February 1, 2008 Share Posted February 1, 2008 Do you really have application for the magic 500hp or is it willy waving chit? classic Link to comment Share on other sites More sharing options...
