question on turbo upgrade
Guest daz 6576
Guest daz 6576
i am changing the turbos on a tt auto j-spec.
it already has a fcd and a sld fitted to the ecu and a boost controller
does it have to be re-mapped and if so why
Guest daz 6576
my turbos are on the way out so i want to put a single turbo on it. i want about 500bhp.
the car already has a fmic, koyo rad, bov,plugs.ect
what turbo is best and were can i get it for a good price
If you're fitting anything other than standard turbos, the pressure/volume of airflow will be different which alters the fuel requirements of the engine. So yes, you will need to remap the fuel injection at a minimum and possibly the ignition as well depending on what spec you're going for.
Guest yoshi_v300
Aren't turbo kits the best way to go? Expensive, yes, but an HKS kit I presume has all the correct sized wastegate, manifold etc.
correct, go for the complete kit, then a fuel kit, then a standalone ecu, then start grinning even with an empty wallet
What is your budget for the complete install? The price of the turbo is a very small part of the overall cost.
Guest yoshi_v300
Just as a side point, I know stock twins can push 450hp if pushed and your setup seems 400hp+ already. Do you really have application for the magic 500hp or is it willy waving chit?
I guess the 550hp turbo kit from HKS is about right for circuit use, as anything above that will have huge lag. It's still laggy though compared to stock twins.
