Oil Cooler Questions
Pixelfill
Hi guys,
A couple of questions related to installing an oil cooler.
I have a Mocal 16 row (235mm) Oil cooler (with 1/2BSP fittings) that I'm thinking of installing on my BPU TT. I also have a Mocal Oil Stat (Which I believe operates at 80C). Would this be suitable for BPU, or is it more suited for a single.
The second question:
Assuming that the cooler isn't overkill, how should it be fitted. Presumably the filter needs to go before the stat which needs to go before the cooler, and then back to the engine. but I can't work out how the Mocal Oil Stat should be "plumbed" in. There are no markings on the outlets, so can anyone give me
any advice as to how it should be connected.
The Stat is an OT/2(C?) top left on this page
Cheers
Mike
If you do track days then an oil cooler definitely isn't overkill. It's plumbed in like this:-
take off -> filter -> oilstat -> cooler
take off
So basically one side of the stat goes to and from the filter and the other to and from the cooler. Oil flows through the filter from the outside to the center, so your hose from the takeoff to the filter will go from the outside of the takeoff, and the return from the oilstat will go to the center.
Many thanks Simon,
I don't suppose you can give me any advice as to the mocal oilstat. There are four outlets and none are marked so I'm not sure which is the inlet, and which is the outlet if you get what I'm saying.
I can't work out what the normal flow (below 80C) would be, and hence where to connect the cooler to the stat.
Mike
No, I prefer the oil temp probe in the sump, and adaptors are avialble for 1/8 NPT sensors to replace the stock sump plug (in stock..). I use the Lexus oil filter housing bolt for the pressure take off, or modify a stock one. I have exchange modded stock ones in stock at 10 quid each plus P&P
  • 2 weeks later...
