eyefi Posted July 5, 2002 Share Posted July 5, 2002 how the hell do u fit an egt probe amongst all that stuff. im wanting to go into the manifold. has anyone got any pics of their install. also my probe element is about 10cm long, why is it so long? by the way my instructions r in japanese and i dont happen to read japanese. a lovely detailed explanation would be nice. thank in advance. Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 5, 2002 Share Posted July 5, 2002 The probe is long to allow just the right amount to poke into the port. It MUST go before the turbos, utterly useless after them. i made up extended drills and extended taps to do this. I can fit the probe for 60 quid if you chicken out. While you wait :-) Link to comment Share on other sites More sharing options...
lee_kelsey Posted July 5, 2002 Share Posted July 5, 2002 Originally posted by Chris Wilson The probe is long to allow just the right amount to poke into the port. It MUST go before the turbos, utterly useless after them. i made up extended drills and extended taps to do this. I can fit the probe for 60 quid if you chicken out. While you wait :-) Chris, I have a probe line fitted, but have not had the guts to drill the manifold myself, so I would be very interested in you doing mine! Where are you based? Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 5, 2002 Share Posted July 5, 2002 Originally posted by lee_kelsey Chris, I have a probe line fitted, but have not had the guts to drill the manifold myself, so I would be very interested in you doing mine! Where are you based? I am just into Shropshire, off the A49 between Whitchurch and Shrewsbury, 20 minutes from Oulton Park. Post code is SY13 2BT. Or ring me on 01948-841581 thanks. Link to comment Share on other sites More sharing options...
JohnK Posted July 5, 2002 Share Posted July 5, 2002 A little off topic, but if you are drilling the manifold before the turbos, in place on the car, how do you stop the swarf getting into the manifold and into the turbos? Link to comment Share on other sites More sharing options...
eyefi Posted July 5, 2002 Author Share Posted July 5, 2002 chris, im shiting myself already, and thats only looking at it, never mind having a drill in my hand! im thinking ill chicken out. ill email u. Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 5, 2002 Share Posted July 5, 2002 Originally posted by JohnK A little off topic, but if you are drilling the manifold before the turbos, in place on the car, how do you stop the swarf getting into the manifold and into the turbos? Special shallow helix drill bit with retention grease. Link to comment Share on other sites More sharing options...
Ian C Posted July 5, 2002 Share Posted July 5, 2002 I've also found that those extendable magnetic grabber things pick up swarf something great. But Chris's bit of kit sounds much sexier. -Ian Link to comment Share on other sites More sharing options...
Nic Posted July 6, 2002 Share Posted July 6, 2002 Mine was tapped into the small Y-section pipe next to the O2 sensor, is this before or after the turbos as I'm getting lower than expected readings (between 4-600degrees) cheers Nic Link to comment Share on other sites More sharing options...
Guest Martin F Posted July 6, 2002 Share Posted July 6, 2002 That's after the turbo's. Link to comment Share on other sites More sharing options...
