Whitesupraboy2 Posted December 29, 2007 Share Posted December 29, 2007 I have a wireless network seems to run fine. I am running a machine about 10ft (in same room) from wireless router and been having speed problems. So I was doing ping tests to google and found pings dropping. So I then decided to ping the router itself and getting time outs to the router. So ive got it down to the connection between router and PC So I got a 2nd USB wireless network card and tried that same problem, changed the channel same problem again. I cant my head round it! Anyone got any ideas? Link to comment Share on other sites More sharing options...
DamanC Posted December 29, 2007 Share Posted December 29, 2007 monitor the traffic on the problem PC. Is it active when it shouldn't be? Link to comment Share on other sites More sharing options...
DamanC Posted December 29, 2007 Share Posted December 29, 2007 Some wireless cards are utter crap, same with the management software. I hate wireless networks, they are very inconsistant. If you get fed up trying, pick yourself a linksys or netgear wireless PCI card up and right that to your router. Who makes your current hardware? Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted December 29, 2007 Author Share Posted December 29, 2007 as far as i can tell no its not, Its got antivirus software on it....Im tempted to format it and start again. Forgot to add signal strength is 'very good' (80%) Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted December 29, 2007 Author Share Posted December 29, 2007 Some wireless cards are utter crap, same with the management software. I hate wireless networks, they are very inconsistant. If you get fed up trying, pick yourself a linksys or netgear wireless PCI card up and right that to your router. Who makes your current hardware? Netgear Router Range max edition 2 Wireless usb cards tried (infront of pc for better signal) * ASUS * Netgear its bugging me, when pings are going through everything is quick when it stops, everything dies on the connection, web page loading the lot. Link to comment Share on other sites More sharing options...
DamanC Posted December 29, 2007 Share Posted December 29, 2007 Yeah its common. Try setting the wireless card to full power/always on in the device properties, it sometimes helps. I have never used ASUS network cards before so cannot comment but netgears are one of the better ones out there, I get about 90% sucess with them. Try disableing your firewall for a short period of time, just to see if anythings changes. Im guessing when you reboot the problem PC, all is fine? Have you tried putting the problem wireless card in the non problomatic PC? If so, what happens? Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted December 29, 2007 Author Share Posted December 29, 2007 its happening all the time. If i leave a ping going, every 10 - 20 succesfull Link to comment Share on other sites More sharing options...
MaveriK Posted December 29, 2007 Share Posted December 29, 2007 Set a ping going to the router as well as google to see if its outbound or inbound errors Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted December 29, 2007 Author Share Posted December 29, 2007 So I then decided to ping the router itself and getting time outs to the router. So ive got it down to the connection between router and PC So I know its inside which is annoying me, nothing is working so far! Link to comment Share on other sites More sharing options...
MrRalphMan Posted December 29, 2007 Share Posted December 29, 2007 What channels have you tried? Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted December 29, 2007 Author Share Posted December 29, 2007 1,6,11. All about same, no particular channel is better then the other. My router has option of channels 1 -13 Link to comment Share on other sites More sharing options...
carl0s Posted December 29, 2007 Share Posted December 29, 2007 Which RangeMax is it? I had similar problems with the DG834PN. I think I got there in the end, after altering/disabling various settings but overall it just didn't work very well at all. Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted December 29, 2007 Author Share Posted December 29, 2007 Which RangeMax is it? I had similar problems with the DG834PN. I think I got there in the end, after altering/disabling various settings but overall it just didn't work very well at all. Good guess...now what are those settings Link to comment Share on other sites More sharing options...
carl0s Posted December 29, 2007 Share Posted December 29, 2007 Well, it's at my mums and I'm rarely there, so it might still be shit but I think I did get there in the end. I kind of thought it was just a duffer because I bought it from eBay, but I suspect they are just problematic. They're an early/pretend MIMO Atheros thing. I'll connect into my mums and see what I have set now.. Link to comment Share on other sites More sharing options...
carl0s Posted December 29, 2007 Share Posted December 29, 2007 Hmm. There really isn't anything in there to set or unset I have : Firmware: 1.03.35 Channel: 11 Mode: g only Wireless Isolation disabled WPA-PSK security that's about it. I normally like to go for WPA2 or WPA1+2 so maybe that had a bearing on things, or maybe forcing G-only. But like I said, it might still be crap. Link to comment Share on other sites More sharing options...
Gaz6002 Posted December 29, 2007 Share Posted December 29, 2007 Simple question. Anything between router and problem PC? Have you tried physically moving the PC? Interferance can be caused by microwaves, cordless phones etc etc and i've heard of this dropping packets. Link to comment Share on other sites More sharing options...
Gaz6002 Posted December 29, 2007 Share Posted December 29, 2007 Also, have to tried hardwiring into your PC? It could be your net connection itself... Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted December 29, 2007 Author Share Posted December 29, 2007 cheers Guys Gaz - Tried hard wiring PC and pinging the router then i dont lose packets. Attached screenshot of packet loss when wireless. When wired all Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted December 29, 2007 Author Share Posted December 29, 2007 Simple question. Anything between router and problem PC? Have you tried physically moving the PC? Interferance can be caused by microwaves, cordless phones etc etc and i've heard of this dropping packets. I had a cordless phone in this room so this got moved about 20ft away and out of the room with the PC and router. I have moved the tower about within around 3ft (space where its kept) and makes no difference. I normally can solve stuff like this but this one has got me! Link to comment Share on other sites More sharing options...
Gaz6002 Posted December 29, 2007 Share Posted December 29, 2007 it sounds to me like an issue with your router then mate. If packets are dropping when wireless but not hard-wired then that would be my next point of call. Does the router stay on all the time? I take it you've tried rebooting? These routers are sometimes not the most stable things in the world, especially if they are kept in a non-ventilated space and left on. My home router suffers from this and so i've designed a ventilation system for it. When you trace out from the PC does it fail at your routers ethernet interface IP address? Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted December 29, 2007 Author Share Posted December 29, 2007 I think its gonna be router too, im tempted to go back a firmware version. As I think I switched to wireless around time I upgraded the firmware. So Guess that could be the problem. When it fails it gets no where doesnt even hit the router. Router is on all the time as well its mounted up on the wall in the room so not covered. Yes tried rebooting it mate. Link to comment Share on other sites More sharing options...
carl0s Posted December 30, 2007 Share Posted December 30, 2007 I think they're just problematic routers. Are you using the 1.3.35 firmware? Have you tried setting it to G-only rather than "Auto-108mbps" ? Lots of PS3 owners having issues with interference (clicky) Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted January 4, 2008 Author Share Posted January 4, 2008 I have found the issue. It is my xbox 360. The xbox 360 polls the airwaves on 2.4Ghz looking for wireless controllers, reason being is you can turn the machine on by the controller, so the only way to remove the packet loss is too completly remove the power cord from xbox 360. Ive had to write to netgear as the router is sold ass interferance 'adapting' device....when its obviously not Link to comment Share on other sites More sharing options...
Gaz6002 Posted January 4, 2008 Share Posted January 4, 2008 I have found the issue. It is my xbox 360. The xbox 360 polls the airwaves on 2.4Ghz looking for wireless controllers, reason being is you can turn the machine on by the controller, so the only way to remove the packet loss is too completly remove the power cord from xbox 360. Ive had to write to netgear as the router is sold ass interferance 'adapting' device....when its obviously not In my professional opinion: that is GAY. Glad you got it sorted dude Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted January 4, 2008 Author Share Posted January 4, 2008 In my professional opinion: that is GAY. Glad you got it sorted dude Yep! they need to start opening more frequencys, so many things using this frequency, it was bound to happen! I think a new router will be needed. Link to comment Share on other sites More sharing options...
