Results 1 to 13 of 13
Thread: ECU Coolant Temp Sensor N/A Same as TT? Removal Help
  1. #1
    Work... what work? Club Member Timlowthian's Avatar
    Join Date
    Feb 2010
    Location
    England - Isle of Wight
    Posts
    354
    Feedback
    11 (100%)
    Hi All
    Am doing a few bits on my friends supra and it needs a new ECU Coolant Temp Sensor. I found this on eBay but cannot find a Non turbo equivalent, are they the same? Is there anywhere else i can get one if they are not? Don't mind a second hand one for diagnostic purposes.
    eBay Sensor:
    http://www.ebay.co.uk/itm/1507067815...ht_1118wt_1111
    Also any one with any tips for removing and fitting the new one as if i'm correct it is the sensor screwed into the block under the power steering assembly is it not? Tried the workshop manual but couldn't see it in there!
    I'm an MR2 person myself so supra's are a new project for me any help or tips appreciated.
  2. #2
    Got the shiny bug. Club Member ripped_fear's Avatar
    Join Date
    Feb 2010
    Location
    England - Hampshire
    Posts
    14,470
    Feedback
    95 (100%)
    cant help with the topic im afraid but you live on the island? Whos/what supra you working on?
    I went from a 220bhp Sapphire Cosworth > Supra TT BPU circa 400 BHP......................BUt dont worry I had plenty of experiance on Mario Kart -scotty71
    If you were an engine would you like JP as your owner:-)? I'd report him to the RSPCE (Royal Society of Prevention of Cruelty to Engines).-Chris Wilson
    That was SupraPond 2010. WaspyPod was a corker, never seen to many wasps in one place.-Branners
    I am bad, but then I'm not a moderator....Im so much more.-Branners
    You are bloody nuts. Nothing comes close dude, what the hell would you replace it with? A GTR, that's like going from Kiera Knightley to Susan Boyle.-Supra Gaz
  3. #3
    What search button? MEMBERSHIP EXPIRED
    Join Date
    Dec 2009
    Location
    Wales - Mid Glamorgan
    Posts
    1,676
    Feedback
    5 (100%)
    no mate it doesnt plug there,
    it goes into the radiator
    easy to do, need to get at it from underneath, its at the bottom of the rad by the drain plug. simple open end spanner on it will do
    i too have just ordered one from toyota, 45+ vat. im not sure if the NA and TT are the same.
  4. #4
    Join Date
    Feb 2010
    Location
    Posts
    354
    Feedback
    11 (100%)
    Quote Originally Posted by ripped_fear View Post
    Hey mate yes i have seen you round and even met you. It is my friend Nat's car met you at Top car park of Cineworld that time ages ago you were with the black supra (luke was it?) It was the silver one with the kit on?
    Quote Originally Posted by Lude View Post
    I thought the one in the radiator was the Temp sensor for the dash gauge? Or at least i'm reading the workshop manual wrong (quite possible btw!)
  5. #5
    Join Date
    Feb 2010
    Location
    England - Hampshire
    Posts
    14,470
    Feedback
    95 (100%)
    Quote Originally Posted by Timlowthian View Post
    Ah I did wonder if it was you! Saw it parked up on the drive the other day when I passed through haylands way. Haven't seen it on the road in ages.
  6. #6
    Posting is my life! Club Member Kaan W's Avatar
    Join Date
    Mar 2012
    Location
    England - Kent
    Posts
    7,900
    Feedback
    54 (100%)
    I thought the water temp sensor was screwed into the top water neck?
  7. #7
    Join Date
    Feb 2010
    Location
    Posts
    354
    Feedback
    11 (100%)
    Yeh its still on the road but the owner doesn't live on the island anymore its back for me to sort out then i'm sure it will be off again.
  8. #8
    Join Date
    Feb 2010
    Location
    England - Hampshire
    Posts
    14,470
    Feedback
    95 (100%)
    Ah fair enough, If you need any spares let me know I have a few various bits kicking around.
  9. #9
    Join Date
    Feb 2010
    Location
    Posts
    354
    Feedback
    11 (100%)
    Ok so now im confused as to where the Sensor actually is? Anyone no on the N/A? Its the ECU coolant Sensor im after not the dash one.
  10. #10
    Join Date
    Dec 2009
    Location
    Posts
    1,676
    Feedback
    5 (100%)
    Not sure if the na is same as TT,
    TT is in the rad for the ecu
  11. #11
    BPU happy Events Organiser Shane's Avatar
    Join Date
    Jan 2006
    Location
    England - Northamptonshire
    Posts
    4,274
    Feedback
    39 (100%)
    I will check and get back to you a little later, but am 99% sure that the sensor in the bottom of the rad is for the OEM supplementry electric fan in front of the rad on TTs. It has normally closed contacts and operates a relay in front of the passenger headlamp and that in turn switches the fan motor in. It has no bearing on the temp feedback to the ECU if I am correct. Someone on here will know this for sure and I will go out later and check anyhow. As previously mentioned, the engine coolant sensor for the ECU will be in or around the head somewhere.
    Could this be the problem with your starting Lude, looking at the wrong sensor?
    Great minds discuss ideas, average minds discuss events, small minds discuss people.
    Satin black BPU. 12.83 1/4 @ Santa Pod Saturday night special May 2015
    N/A auto, Red..Sold
    N/A Auto Silver..Sold
    Daily commute Nissan Navara D22 twin cab PU, soon to be on veg Mercedes W210 E300TD powered by veggie oi, Mercedes W202 250 TD, Powered by chip oil
    Vauxhall Tigra with Isuzu diesel engine conversion. Powered by chip oil
  12. #12
    Join Date
    Feb 2010
    Location
    Posts
    354
    Feedback
    11 (100%)
    Thanks mate didnt think it was radiator! Im trying to find it to chnage myself as it struggles to start without help when cold! Toyota want 55 for the sensor which i didnt think was bad but somehow couldnt tell me its location on the engine that worried me a bit!
  13. #13
    Join Date
    Dec 2009
    Location
    Posts
    1,676
    Feedback
    5 (100%)
    I thaught was in the rad, til i wen to change mine yesterday and it didnt fit.
    Not sure where it is on the na, TT is by the water pump though iv jist changed mine now.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
