what primer to use on alloy?
ECK
 Share
just refurbing my split rims but some of the paint has peeled off!
i was pissd as it took 2 days to get it that way
i think im useing the wrong primer!
is there a special primer for alloy?
here is a pic of the wheel with the fault!
any help would be great
thanks in advance
alex
I got mine from Halfords.
A large can , approx £10. :blink:
Made by Upol, good stuff.
thanks mate ill be down there tomorrow!!
i had a look at that stuff too and put it back on the shelf for the cheeper option!
thatl teach me eh!:rolleyes:
One more tip when priming alloy,make sure you get out all the past corrosion, and wipe well with spirit wipe before priming.
i did that mate but i used meths for cleaning the wheel is that right?
i also wiped down with a tacky cloth
thanks for the tips tho!:) ;)
I just done my spare set of wheels and used all Halfrauds own brand stuff.
I left my primer to dry over night and gave them two coats, then did the same with the paint and then lacquered them.
EDIT: just to add, I washed mine with petrol before painting.
Bad move i'm afraid:( petrol leaves a residue, hope the paint stays on there, meths is far better although not ideal.
Body prep , body clean stuff is what you use when doing the bodywork of a car.
About £10 from a motorfactor for 5 litre.
It's good stuff!
Meths can dissolve the paint, especially primer. Not as harsh as thinners.
Thinners is only good on bare metal, it will soften the paint.
  • 5 weeks later...
I left about week between cleaning and painting and wiped them down with a damp cloth.
They seem ok at the moment as I have just had some new tires put on them.
 Share
