Fuel rail
RobSheffield
  • Replies 57
Posted Images
Cheaper solution yes, but why is that a bad thing.
The fuel rail is just a piece of metal with a hole through it, why pay for another one in a pretty colour?????
I think it already been mentioned that the stock unit has a larger ID than some aftermarket units.
Ive recently bought an aftermarket fuel rail. The stock rail doesnt have a larger ID than most aftermarkets. Apart from that, the fact that the oe rail is side feed is not such a great thing. If you think about it, the last injector is recieving fuel that has passed through the other 5 before. This is 5 injectors cycling the fuel and causing pulsations in the flow. The top feed system gives fuel to each injector that hasnt passed through the others. If your rail is duel feed then fuel enters from both sides giving an equal flow to both ends of the rail. On full throttle, which is when all of this really comes into play, you dont really want fluctuations in the fuel going to the cylinders.
ps. These are conclusions I have logically come to and could be a steamy pile of shite:)
Mr CW was talking about the skyline setup on fuel rails. Ive got a j-spec supra rail here and it is a small ID. I also agree with him in that most fpr are junk. The rail will only operate as well as the pressure of the fuel in it. A combo of good pump setup and fpr should ensure a constant pressure of fuel to the rail/injectors. :)
The selection of a single pump setup is ideal because if the pump fails you will just cut out. Whereas with the dual pump setup, if one pump goes you can run lean(top end) due to low fuel pressure. I reakon you can resolve this issue by just having a gauge with warning alarm in the car. Im running dual Walbro255's.
I'm thinking about this too with a stock UK spec pump I have kicking around, will be interested to see how you get on (I suspect you'll get there long before I do :))
I wouldnt suspect too hard :p
I have a bizzare pump in at the moment, and was going to replace with a Walbro, but i guess i dont actually need to as it just needs to fill the swirl pot, and so doesnt matter about the pressure or flow rate.
Have you seen flow charts for that bosch pump? I don't think they flow much (if any) more than the stock Supra pump? They are a good pump quality-wise, but the flow is lacking. Some good info here
http://www.stealth316.com/2-fuelpumpguide.htm#j6
The fuel rail discussion is good, depending on your fuel flow requirements sometimes the larger diameter is needed. A too-small rail can actually have less pressure on the outlet end vs the inlet end. The stock rail is pretty good, but if you are putting in 800cc injectors or so, and plan to be using them to their fullest, I'd get a larger rail. The HKS is not terribly larger ID, I'd get the Titan, etc as they have the 17mm ID stock.
DaveH
'93 na-t SP73/AEM
9.46 @ 143mph
Worlds quickest NA-T Supra
Some of CW's opinions on the subject.
HERE and HERE
On this occasion I couldn't disagree with Mr Wilson more.
I don't know it he's actually seen the difference in diameter between the stock and say the PHR fuel rail, but let me enlighten you...
Stock:-
PHR:-
The PHR fuel rail is 17mm I.D. (IIRC it's certainly something of that order, I'll try to find a pic with a scale in...)
Also, if you are changing fuel injectors, due to the fact that there is no standard pressure that all injectors are flow rated for, it is very unlikely that the injectors that you buy will have been flow tested at the stock base pressure. If you run at a different pressure then your 700cc injectors will not be flowing 700cc's. It could be more, but it could be less. The only way of ensuring that they flow the amounts that they have been tested to is to fit an adjustable fuel pressure regulator and set it to whatever pressure the injectors have been tested at.
If you're running the pressures at anything less than what they're tested at then you're robbing yourself. You might as well just buy much smaller injectors and ramp the pressures right up... (If people are happy to do that then I've got some 440cc, I mean 800cc injectors for sale that will fit a stock rail! ;) )
Whilst on the subject of fuel pumps, does anyone know what pressure the Walbro (Or any pump for that matter!) is tested to flow 255 l/hr at? Without knowing that figure is meaningless....
I mean say if it is 30 PSIG (I seriously don't think it is!) then it's supplying 255000cc per hour. Say your injectors on your single are rated to 800cc at 30 PSIG then they require 48000cc of fuel supplied. If that's the case would I be worried about losing 1 pump? Not with over a 5x factor of safety. No.
However if the pump is rated at a much much higher pressure than the injectors then it could be a completely different story... See what I'm saying?
