Prof. Monkey Posted September 27, 2006 Share Posted September 27, 2006 Hi bought an engine stand, to mount my engine on, whilst I work on it, can you tell me which points on the engine (flywheel end) are best used and which bolts I should use. If you know the the thread type and size that would be of great help.... Many, many thanks. Darren Quote Link to comment Share on other sites More sharing options...
Prof. Monkey Posted September 28, 2006 Author Share Posted September 28, 2006 Anyone? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 28, 2006 Share Posted September 28, 2006 Mount on 4 of the bellhousing bolt holes, and space the arms fairly equally around the block. Use good grade bolts with adequate thread in the block. A lot of el cheapo stands won't safely hold the weight of a fully dressed MKIV engine. Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 28, 2006 Share Posted September 28, 2006 They are something crazy, those bolts, something like M14 or M16 metric fine, absolute bastard to find. -Ian Quote Link to comment Share on other sites More sharing options...
Prof. Monkey Posted September 28, 2006 Author Share Posted September 28, 2006 Thanks has anyone got the particular bolts I need? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 29, 2006 Share Posted September 29, 2006 You will have them, use the original gearbox bellhousing bolts, with spacers if required. Quote Link to comment Share on other sites More sharing options...
Prof. Monkey Posted September 29, 2006 Author Share Posted September 29, 2006 Thanks for that Chris Thankyou Quote Link to comment Share on other sites More sharing options...
