Conrad Posted August 26, 2006 Share Posted August 26, 2006 I have a Blitz dual BC which I'm gonna be fitting tomorrow. I bought it because when I went BPU my restrictor ring was resticting me to 0.9bar. I took the ring out and now I get 1.2 maybe a touch more. I thought if I fitted the BC I could just set it to 1.2 and it wouldn't go over that. But Thorin said on another thread that the BC wont stop it going over 1.2 if it is already, you ony use the BC to up the boost. Is this true? And if so will I need to put my ring back in and then up the boost to 1.2? Quote Link to comment Share on other sites More sharing options...
Nic Posted August 26, 2006 Share Posted August 26, 2006 Thorin is absolutely correct, a boost controller can only raise boost, it cannot limit or lower boost. I would suggest refitting the restrictor ring, then use the boost controller to raise the boost to 1.1 - 1.2bar. You will see a slight rise in boost pressure in colder weather, so if you are going over 1.2bar now, you will be seeing even higher readings come winter Quote Link to comment Share on other sites More sharing options...
wkdtime Posted August 26, 2006 Share Posted August 26, 2006 Conrad as Nic said, id leave the restrictor ring in and use the EBC to increase the boost, this way you have better control over the boost and also decrease the chance of boost spikes drasticly with winter comming. Quote Link to comment Share on other sites More sharing options...
Conrad Posted August 26, 2006 Author Share Posted August 26, 2006 Thanks for the info, I'll pop he ring back in then Bit confused now as to how the BC works but hey, as long as it works I'm happy! :) Quote Link to comment Share on other sites More sharing options...
Nic Posted August 26, 2006 Share Posted August 26, 2006 Thanks for the info, I'll pop he ring back in then Bit confused now as to how the BC works but hey, as long as it works I'm happy! :) http://www.streetracersonline.com/articles/turbo/boostctrl.php Quote Link to comment Share on other sites More sharing options...
wkdtime Posted August 26, 2006 Share Posted August 26, 2006 Conrad, look at it like this, the boost controller can only increase boost from the cars base boost limit that is controlled by the wastegate or restrictor ring, it cannot lower the boost below it. e.g , stock TT makes 0.8 Bar, if you place a boost controller in the system now, you can now only increase the boost from 0.8 and cannot lower it below it because this is bascially your base boost that is controlled by the wastegate. Quote Link to comment Share on other sites More sharing options...
Conrad Posted August 26, 2006 Author Share Posted August 26, 2006 Conrad, look at it like this, the boost controller can only increase boost from the cars base boost limit that is controlled by the wastegate or restrictor ring, it cannot lower the boost below it. e.g , stock TT makes 0.8 Bar, if you place a boost controller in the system now, you can now only increase the boost from 0.8 and cannot lower it below it because this is bascially your base boost that is controlled by the wastegate. Oh I see, I get it now. Cheers bud. Quote Link to comment Share on other sites More sharing options...
Thorin Posted August 26, 2006 Share Posted August 26, 2006 Thorin is absolutely correct I always am, people should listen to me more often Quote Link to comment Share on other sites More sharing options...
Conrad Posted August 26, 2006 Author Share Posted August 26, 2006 I always am, people should listen to me more often I never doubted you, honest! Quote Link to comment Share on other sites More sharing options...
