Airbag problem changing from 4 to 3 spoke steeringwheel
bamboo rocket
 Share
I have bought a nice 3 spoke Toyota steering wheel, instead of my old 4 spoke – and wanted to install it today. But there is a few problems.
The airbag connecters are not the same, can I buy a plug/connecter somewhere or any other ideas?
http://images.bilgalleri.dk/uploads_alb_large_wm/1176359_l.jpg
http://images.bilgalleri.dk/uploads_alb_large_wm/1176360_l.jpg
http://images.bilgalleri.dk/uploads_alb_large_wm/1176357_l.jpg
http://images.bilgalleri.dk/uploads_alb_large_wm/1176358_l.jpg
Another concern
In the bottom/mounting point on the old 4 spoke wheel is there 3 holes that fits to 3 points on the steering rack
On the new 3 spoke wheel there are no holes – but when I mount on the steering rack it seems fine.
Anything to worry about?
http://images.bilgalleri.dk/uploads_alb_large_wm/1176361_l.jpg
http://images.bilgalleri.dk/uploads_alb_large_wm/1176362_l.jpg
http://images.bilgalleri.dk/uploads_alb_large_wm/1176363_l.jpg
There could be an easy way to do this as I'm sure someone on here must've fitted a newer steering wheel, in the meantime here's my reply. :)
You could buy the connectors, or remove the connector from the old airbag and fit it to the new one. Obviously you need to make sure the wires are connected the right way around.
I don't mean to sound rude but it sounds like that you're not very familiar with electrics, soldering, connectors and stuff, you may be safer getting someone else to do it for you. :)
Connector info from Supraforums.com, bare in mind that this is for the US car but it may well be the same.
I seem to remember reading somewhere (a long time ago) that the impact sensor for the airbag was changed on the facelift Supras.
You may find even if you do get it connected up that it might not work as it should, not something you can easily test either :scare:
No problem, you are right – I am learning by doing :D
(But dangerous when playing with airbags :bang:)
See this thread, sounds like you need an airbag adapter harness
http://www.mkivsupra.net/vbb/showthread.php?t=157220
Thanks for the advise – I have PM carl0s – for information about the airbag adapter harness he used.
Carl0s have helped me with the part number for the airbag adapter harness -
From Carl0s:
It's a standard Toyota part. I will find the part number for you. It comes up on Toyota's system as "special service tool", but it's the adapter. - the part number is 09082-00760
Will order one straight away – big thanks to Carl0s for his help :)
This is what that looks like....it allows connection from Atype clock spring cable to Btype airbag clip
http://img695.imageshack.us/img695/8972/ccccccccct.png
....your horn connector should be the same .
Note ..Your disconnecting your neg battery cable ( before ) you do any of this right !!
cheers
Edited by mugg (see edit history)
 Share
