Drag Cams Like 280's
StuartW
 Share
Well i have been put off the Crowers due to stories of Damaged items,poor hp results and general lack of results.
Its a coin up between HKS or GSC stage 2
There seem to be better results from GSC's
The prices are
Per pair Brian Crower 280 $632
hks 280 $938
gsc'S Stage 2 $899.65
Heres what MVP say about GSC stage 2;
Stage 2: The S2 cams are designed for those running a large single turbo, larger than 71mm. These cams will not have bottom end losses over the S1 cams; nothing but gains will be seen and will promote great peak power gains. Gains of 60-100rwhp (depending on turbo) have been seen by simply bolting the S2 cams in and reshimming.
Designed for a rev range of 4000-8500 RPM's, these cams require upgraded valve springs, but can be run on stock cylinder heads. 800-1100rwhp camshaft set with a rougher than stock idle.
Intake 274 Duration 10.20mm peak lift, 109 degree Centerline
Exhaust 274 Duration 10.20mm Peak Lift, 119 degree Centerline:D
Dusty says these have given better results over HKS even though he is an HKS dealer!
Any thoughts??
  • 2 weeks later...
Not what you originally posted up for but i have an Hks 256 intake and an HKS 264 exhaust cam. PM to discuss if you want Stuart.
cheers for the offer but i am already running 264 264 on the road car and have now ordered the GSC's for the drag car :D
 Share
