Induction Kit Benefits
simbasupra
 Share
Just been reading this thread:
http://www.mkivsupra.net/vbb/showthread.php?t=138283
where nic said
"Remove the HKS induction kit and fit stock airbox, with either stock or TRD filter element. The HKS filters are notoriously bad at filtering and won't be doing any good for the life of your engine and turbos. The stock airbox is not restrictive and includes 2 cool air feeds, so you will probably notice an improvement in performance compared to the HKS filter, which draws in hot air from the engine bay."
and this technical article:
http://mkiv.com/techarticles/filters_test/2/index.html
Just wanted to know what the best option is for induction. (performance, reliability)
Standard airbox with standard panel filter
Standard airbox with aftermarket panel filter (state choice)
Aftermarket induction kit (state choice)
I was going to do a poll but cant figure out how to do one:rolleyes:
No worries, basically to summarize for you....keep the stock airbox with a stock panel filter or if you want a TRD filter for a stock performing car or BPU.
Like I said in my post....for a small single turbo I would love to keep a similar setup if it would allow.
so would the standard airbox / trd filter combo be better than the apexi induction kit in the test:
Dyno tests are generally done with the bonnet open, with a huge fan blowing air at the front of the car, in this situation the induction kit may slightly improve power.
In real world driving, the induction kit will be drawing air in from a hot engine bay and will probably lose power.
 Share
