Anti surge thingymajigs
CJ
They will help protect the computer when there are cuts/surges, but if you want the best protection get a top end power supply unit, most have protection build into them that sheilds the power to the motherboard in case of any spikes/failure. They aren't cheap though, over £80 I think.
UPS would be your best bet.
They regulate the power supply to your PC and protect from spikes. Will also provide battery to prevent power loss.
Are there cost effect home units available Pete? I'm only used to working with 'big stuff' when it somes to UPS's
Do you really need an APC? Pretty sure a decent powerpack would do you just fine. If you run a business from home though i would think about it.
Scott =op
It isn't so much a business issue (although I do get paid for working via the net and am looking at expanding) but more that the PC and Mac I have here are my only real sources of keeping in contact with the UK and I would not want the power problems on the island to muck up the hardware.
Just get a decent powerpack then. The good ones have a few little tricks inside them that stop damange via surges, spikes, powercuts etc.
Thermaltake ones have REALLY come down in price. I just had a look and you can get one to suit most peoples needs for around 40 quid. All the thermaltake ones have the protection you require.
Scott =op
Scott =op
Could you please point this technical numpty to a site that might sell these please?
I'll disagree with you on this....
Powerpacks aren't really suitable for decent usage, remember if they were any good they would be used in commercial data centres.
I've got an APC 1000VA unit, which gives me around 15 minutes of run time on my two pcs. The APC stuff is superb at doing brown out filtering.
Have a look here and see which one you need...
http://www.thermaltake.com/
You basically want to look for one around the same wattage as the one you have, or above, with the connections you require (depends on how many HDD's, CD-Rom's, floppy drives etc. I'm pretty sure if its just a standard PC the most basic one will do.
Noticed your in Greece, Ebay ok?
Scott =op
I agree about the APC stuff for commercial use etc. But i don't think the issue is the computer turning off i think the issue is when it does turn off it takes the memory and motherboard with it.
My pc's have been in a few powercuts and only 1 powerpack has bit the dust. Took some memory with it too. Bought a thermaltake powerpack and even though its seen its fair share of powercuts i've never had an issue.
Oh, i also have my PC plugged into an anti-surge multi adapter thing.
Scott =op
The problem with things like that, is that don't protect against brown outs, yes they may stop power surges, but brown outs are equally dangerous. Little more money yes, but the cost of replacing hardware outweighs it personally...
If I was a belt and braces man, I'd use both, so yes I do like the thermaltake item as well (not knocking it :) )
