decided to wire in fog switch and tell tales
Pulley
 Share
Looks very tidy. I like that.
Where did you get both fog light bits from? When I installed mine I use a stock rear fog switch from a UK spec but ended up placing the light switch in the top right warning cluster.
Yours looks much nicer.
i did the same, then decided to source some tell tale templates from scrap dash bits i had, found the correct size and installed, i got my right lower dash panel from keron and wired in my headlight level adjust, so thought id have a go at putting in the telltales for front n rear fogs too
I'm at a total loss as to how you made that look so factory. Got any picture of the tell tales going in?
What did you use to etch the black film? A scalpel?
kinda, i had an assortment of different shaped scalpel moddeling knives, i used a screwdriver shaped flat tip one, just carefully etched away, then checked with a light behind to see how much more i needed to do so the template worked, i also used some enamel black modelling paint around the template to ensure no light bleeding thru
tried to make it look as oem as possible, and i certianly cant tell they werent like that from the factory when they are illuminated
Edited by Pulley (see edit history)
 Share
