Vibration on an auto
Bossco
I'm getting a vibration but it olny happens when the car is in drive and my foot is on the brake. In neutral or in park it's fine.
When your in the car it sounds like is coming from the down pipe, when you outside the car it sounds like it's coming from just in front of the 2nd cat.
Any ideas? I'm hoping its a crack in the exhaust but I cant get the car anywhere to be looked at until the week after next.
Facelift car or pre-facelift? I get this a bit, but it sounds more like it's coming from the dashboard on mine (so could be engine mounts, although they were replaced under 2yrs ago but maybe with the same faulty facelift ones). Exactly as you say, it only happens in Drive with foot on the brake.
I had exactly the same problem when 1st bought mine.Hold it on the brake in drive at a set of lights and you gotta vibration through the car and off the dash and it went when you put it in nuetral.Changed engine mounts and it was fine.Its common on them especially facelift models which mine was.
