djskeme Posted December 7, 2007 Share Posted December 7, 2007 HAd a go at this yesterday, and my god is it impossible to budge those pipes. Anyone offer any advice to remoivng it without ctting the pipes....i dont wanna do it the bull in a china shop way in case the new one doesnt fit too good, or the car doest feel as good as the standard one. Thanks Link to comment Share on other sites More sharing options...
jim_supra Posted December 7, 2007 Share Posted December 7, 2007 Have you tried using large pliers on the pipes and spinning/twisting them to break the seal? Link to comment Share on other sites More sharing options...
tDR Posted December 7, 2007 Share Posted December 7, 2007 Yeah just twist the BOV itself with the retaining clips undone. They're actually pretty easy to come off... Cheers, Brian. Link to comment Share on other sites More sharing options...
mikeyb10supra Posted December 7, 2007 Share Posted December 7, 2007 Have you tried using large pliers on the pipes and spinning/twisting them to break the seal? if you do use pliers be careful as the brittle hoses can be torn up using pliers....if you can try and twist em about a bit to losen them and pop em off Link to comment Share on other sites More sharing options...
jim_supra Posted December 7, 2007 Share Posted December 7, 2007 if you do use pliers be careful as the brittle hoses can be torn up using pliers....if you can try and twist em about a bit to losen them and pop em off Yes good point, I've never had this problem myself, but i've heard of it. Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 7, 2007 Share Posted December 7, 2007 Get new hoses from Toyota, and then you can replace it if you wis. If those hoses are hard, so will many others be, and this is the cause of sequntial and other issues. Check them, and if the others are hard renew them, with Gates or other top quality RUBBER hose, or new stock ones, NOT silicone, as the small bore stuff has no fabric liner in 90% of the stuff you can easily buy, and splits and tears. Link to comment Share on other sites More sharing options...
