new engine
gaz1
going up to birmingham to pick up the new engine tommorow, so if you see a 57 plate black hi lux with a engine in the back give me a toot:d just got to work out how too bloody get there:( i have not seen another supe in months so get out for a drive tomoz:d
Your replacing your whole engine because of valve stem seals.........:blink:
err sort of i am changing the turbo system as well, when you look at the price to do the valve stems, then the thought if they have gone then there could be more probs ahead, i try to eliminate problems before hand,(if that makes sense i am half pissed now):D
Good luck on your drive mate, but your probably nearly back by now! :p
If you had asked i could have done the stem seals with the head still in place for considerably less than the cost of a new engine!! ;)
hello mate, yeah it would have been a lot cheaper to do the valve seals, but the built engine came up and i could not resist;)
