Epic Posted October 2, 2007 Share Posted October 2, 2007 Last night i was out in the supra just cruising, and was fine, today i go to drive it and its trying to idle at around 400-500rpm, bouncing between the two like on the edge of stalling it self! (This is an auto) When you drive it fine, but when u stop at a junction or generaly stop the car vibrates coz the rev are so low.. Im thinkin idle control valve, but not sure if you have had any problems like this in the past Only had the car a few days been looking after it, i dont want any problems Quote Link to comment Share on other sites More sharing options...
osso Posted October 2, 2007 Share Posted October 2, 2007 Could be a number of things, might help if you list the mods your car has... when were your spark plugs last changed? do you have an aftermarket fuel regulator? Quote Link to comment Share on other sites More sharing options...
Epic Posted October 2, 2007 Author Share Posted October 2, 2007 Cars Totaly standard, its Daves old car. Sparks couldnt have been changed that long ago either... Quote Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted October 2, 2007 Share Posted October 2, 2007 Would checking for error codes help ? Quote Link to comment Share on other sites More sharing options...
hoff Posted October 2, 2007 Share Posted October 2, 2007 Is your an auto? Mine does this occasionally. Check the error codes 1st I would say. I didnt bother though to be honest, it just happens now and again. Quote Link to comment Share on other sites More sharing options...
Cadburys Purple Posted October 2, 2007 Share Posted October 2, 2007 Mine does this now and again also! Mine's a manual, but I've heard it could be the O2 sensors??? Quote Link to comment Share on other sites More sharing options...
hoff Posted October 2, 2007 Share Posted October 2, 2007 That was one of the suggestions made to me Geth. Probably worth putting them in some Lemon juice before buying some and see if it helps. Im lazy though so will just buy some;) Quote Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted October 2, 2007 Share Posted October 2, 2007 Does this lemon juice thing really work ? Quote Link to comment Share on other sites More sharing options...
hoff Posted October 2, 2007 Share Posted October 2, 2007 Apparently. Probably something to do with its acidic qualities being able to shift the muck that gets on them. People suggest leaving them soaking for 12 to 24 hours. Quote Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted October 2, 2007 Share Posted October 2, 2007 maybe worth a try then ,if it works its a free fix as o2 sensors are abit pricey if i remember Quote Link to comment Share on other sites More sharing options...
hoff Posted October 2, 2007 Share Posted October 2, 2007 Nic does them in a group buy, £75 each. Normally about £100 each. Quote Link to comment Share on other sites More sharing options...
miko_supra Posted October 2, 2007 Share Posted October 2, 2007 yeah mine has does this once or twice. just a quick blip of the throttle makes it all good Quote Link to comment Share on other sites More sharing options...
Epic Posted October 2, 2007 Author Share Posted October 2, 2007 I just been back out in it and its fine again lol. i was like well worryed!!! i will try the lemon thing if it happens again, thanks for the feedback guys, glade it aint just me! Quote Link to comment Share on other sites More sharing options...
carl0s Posted October 2, 2007 Share Posted October 2, 2007 My old UK car did this occasionally, and my new J-Spec car has done it maybe once or twice up to now. I think I just stuck the A/C on when it was doing it. I had presumed it was to do with me fitting colder plugs or something (for BPU). Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted October 2, 2007 Share Posted October 2, 2007 the lemon juice thing does work i done it recently while i had my turbos out. Quote Link to comment Share on other sites More sharing options...
hoff Posted October 2, 2007 Share Posted October 2, 2007 My old UK car did this occasionally, and my new J-Spec car has done it maybe once or twice up to now. I think I just stuck the A/C on when it was doing it. I had presumed it was to do with me fitting colder plugs or something (for BPU). It only started with mine when changing to colder plugs, it did cross my mind it may have been that. Next time I'll try putting the AC on too:) Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted October 20, 2007 Share Posted October 20, 2007 any body answer my question please,,,,, i have got this idle problem where it is between 400-500 and it has cut out on me too. it sound quite tappy but it was fine on the last run before all these symptoms accured any one got any idears Quote Link to comment Share on other sites More sharing options...
Epic Posted October 20, 2007 Author Share Posted October 20, 2007 mine neva actualy cut out. and since i gave it a few blasts has been alright, and i jus tend to cruise about in it and it runs fine again. think i will try the lemon trick one weekend tho just for the sake of it.. Quote Link to comment Share on other sites More sharing options...
hoff Posted October 21, 2007 Share Posted October 21, 2007 Mine did a few times. Not just when sitting at junctions, when slowing down to stop also. Quite dangerous. Do each of the things mentioned in the thread, and also do a search for other suggestions. Quote Link to comment Share on other sites More sharing options...
