jot_ie Posted September 17, 2007 Share Posted September 17, 2007 need to change my rear wheel bearings been quoted the following (parts only) from toyota:- Rear Bearing: €121.37 qty * 2 +vat@21% Rear Hub: €165.91 qty * 2 +vat @21% Anyone know what parts are supplied with each of the above Also do the bearings come with seals etc? Is the hub supplied as a complete assembly (i.e with bearing, seals,flange etc) or just the bare hub only. Also does anyone have a pic showing the Drive flange.( no idea which part it is) I hear it should be replaced at the same time. Many thanks John Quote Link to comment Share on other sites More sharing options...
Guest Chumpalot Posted September 17, 2007 Share Posted September 17, 2007 subscribed to this as I'd be interested in knowing this also. I may be wrong but I think the bearing seals come seperately. Quote Link to comment Share on other sites More sharing options...
jot_ie Posted September 18, 2007 Author Share Posted September 18, 2007 someone must have some answers. Anyone? Quote Link to comment Share on other sites More sharing options...
madwoody1 Posted September 18, 2007 Share Posted September 18, 2007 got to d o this myself but why do you need the hub? and i think you do have to buy the two lip seals two for each side Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 18, 2007 Share Posted September 18, 2007 I keep bearing kits in stock, cheaper than that, but if you are in S Ireland postage is very expensive. I would need to see the EPC picture to know what Toyota call the rear hub, the part you probably need I would call the wheel flange, and you may need an outer C/V joint as well, but I think Toyota only do complete drive shafts. You need to strip it and examine it for wear first. Until you have done a few you may find it hard to determine worn from just a bit mucky... Quote Link to comment Share on other sites More sharing options...
