Guest Jason-B Posted August 5, 2007 Share Posted August 5, 2007 Hi peeps, i have recently fitted some GAB shock absorbers with gmax springs to the soop and noticed on the top of the dampers there is a little plastic indicator with some kind of adjuster marked 1-4, what is that for and what does it mean? ive attached a poor photo of the adjuster: Link to comment Share on other sites More sharing options...
wile e coyote Posted August 5, 2007 Share Posted August 5, 2007 Just a guess its for the stiffness (Hard to soft) Link to comment Share on other sites More sharing options...
Guest Jason-B Posted August 5, 2007 Share Posted August 5, 2007 Just a guess its for the stiffness (Hard to soft) Which would be hardest 1 or 4? ive tried adjusting it and cant really notice much of difference, anyone know which position would be for which setting? Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 5, 2007 Share Posted August 5, 2007 They are VERY easily broken, if someone has ever forced the thing there will be internal damage that's uneconomic / impossible to fix. This MAY explain your problem. Link to comment Share on other sites More sharing options...
Guest Jason-B Posted August 5, 2007 Share Posted August 5, 2007 They are VERY easily broken, if someone has ever forced the thing there will be internal damage that's uneconomic / impossible to fix. This MAY explain your problem. Thanks Chris, it doesnt see broken as you need to press down and then turn which induces a "click" when it engages into each position. Which number would be the hardest/softest? Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 5, 2007 Share Posted August 5, 2007 The adjustment will be 1 for full soft, and 4 for full hard. They should click into position, sounds hopeful Don't force the adjuster AT ALL, otherwise they are scrap. Link to comment Share on other sites More sharing options...
