bolarbag Posted July 18, 2007 Share Posted July 18, 2007 Looking at installing a hydraulic handbrake for the track.... http://www.driftworks.com/catalog/products/driftworks-hydraulic-handbrake-normal-or-upright.html http://www.driftworks.com/catalog/images/large/hydraulic-handbrake1.jpg and http://www.d2racingsport.co.uk/images/OilHydraulicHandbrakes.JPG I'd plan to keep the standard handrake but move it to the left handside, using it only for parking...I'm sure there are legal terms for a handbrake too...needs to have a wire or something I read.... Would like to know what other parts I'll need apart from the braded lines, as I understand it, the hydraulic item still utilises the handrake shoes...is there such a thing as uprated handbrake shoes...? If not, what oem parts are needed when changing handbrake shoes? Cheers Quote Link to comment Share on other sites More sharing options...
Homer Posted July 18, 2007 Share Posted July 18, 2007 What exactly are you planning using this car for? Unless it's some sort of rally cross why would you need one of these. The main issue I can see is that the stock Toyota system is designed only to be used to hold the car, it's not exactly great when used to do a hard lock up on the rears (which need serious bite). The drum system itself is designed to use a cable (pull) system so cannot see how you could integrate a hydraulic system without redesigning the way the drum operates. Perhaps a simpler option would to remove the drum system completely and use an additional single pot calliper on the disc? Like your thinking though... Quote Link to comment Share on other sites More sharing options...
bolarbag Posted July 18, 2007 Author Share Posted July 18, 2007 Perhaps a simpler option would to remove the drum system completely and use an additional single pot calliper on the disc? Nice idea too, has it been done before? It's only really for track...but I have a fetish for going sideways:innocent: The oem handbrake, is litteraly sh*t at hard locks, and with my new driving postion its just in the way, I need to move it to the left handside, or alternatively design another frame for the handbrake to sit further back and central. But if I was to solely rely on that it wouldnt be at an accessable place, and still wouldnt improve the locking performance hence the need for the hydraulic item, but you idea has got me thinking, it may save a bit of weight too! On both these handbrake models they can be sat up right, for faster access, a nice practical idea I thought as if it was a quick change, if could be upright for spirited driving and horizontal for daily use...this could probably be incorporated in Homers idea Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 18, 2007 Share Posted July 18, 2007 I guess it would be possible to make another/duel circuit for the rear callipers, that should give enough bite. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 18, 2007 Share Posted July 18, 2007 It'll be tricky due to the dual circuit braking system. It's easier on cars that have sing circuit, and dual master cylinders (race / rally cars). Quote Link to comment Share on other sites More sharing options...
