no more boost and black smoke
Spoony
hi
yesterday at 11pm i made some videos on our autobahn. when i drove 130 miles the boost pressure got lost.
i stopped the car, the pressore was always -0,2 bar, no boost and no vacuum.
i drove home carfully with 60 miles. car is running as long as i drive slowly.
today i checked if one of the intercooling piping is broken.
everything is ok, no lost of pressure in the intercooler or the piping.
i started the engine, black smoke came out of the exhaust, no boost and the car begins to stotter like yesterday.
what else could be broken? i hear the turbos spinning but no pressure. is there anything inside the oem twins that can make an error like that? im wondering that it doesnt show any vacuum. normally i have -0,7 bar when the engine runs
sorry for my bad english, hope you understand what i am talking about :)
if its export spec, IE for europe then it should be the same as a Uk car no?
So black smoke and loss of boost pressure is usually a popped off hose or a split hose, double check very closely for spit pipes/hoses
You sure its black smoke, not blue, black would indicate excessive fuel been burnt AFAIK
ok i found it!
one of the pipes from the pressure sensor at the intake side was droped off. there was a t-adapter for the boost gauge.
thank god :D
the car is doing 1 bar now, everything oem, just a new fuel pump. is 1 bar ok or do i have to take other sparks?
its a jspec, 2nd cat removed and spec nür catback.
how much hp should it make right now with 1 bar? :innocent:
you want to watch that if you've taken it from the stock FPR point.
could make you run a little lean at high revs which could be, well, devastating. Make sure its tight...
1bar = around 340-360 bhp im not totally sure
