Sean1933 Posted July 1, 2007 Share Posted July 1, 2007 I can get hold of 6 injectors with clips, either Delphi of Seimens, sizes 788cc or 903cc @43.5psi base...for $415 delivered from the states, so about 220pounds i guess. Waiting on a response on if there high/low imp. How much are resistor packs if required? Is this a good price, and which make should i go for (i assume there both good makes)? Probably going for the 788cc as running a GT4088. Cheers Quote Link to comment Share on other sites More sharing options...
JustGav Posted July 1, 2007 Share Posted July 1, 2007 Sounds like this is from fiveomotorsports? If so, I've had good service from Bruce in the past... Which ECU are you plaunning on using, because that would answer the high/low question... Quote Link to comment Share on other sites More sharing options...
Sean1933 Posted July 1, 2007 Author Share Posted July 1, 2007 Its from someone on supraforums called Spoolint78 (i think). Do you have a webpage for your supplier, and what would your preferance be? Will be running on Apexi PFC. Quote Link to comment Share on other sites More sharing options...
JustGav Posted July 1, 2007 Share Posted July 1, 2007 http://www.fiveomotorsport.com/ Run by a guy called Bruce Holt.. Very good service, and very quick with postage I found... Quote Link to comment Share on other sites More sharing options...
Sean1933 Posted July 1, 2007 Author Share Posted July 1, 2007 Nice, thanks. So you think its a good price then? Which ones would you go for? Quote Link to comment Share on other sites More sharing options...
Nic Posted July 1, 2007 Share Posted July 1, 2007 Seems a good price, make sure they will fit in the rail you intend to use, as I think some of the US injectors use different size collars. I supply new OEM Toyota resistor packs for £80 inc postage. Quote Link to comment Share on other sites More sharing options...
