Warning Light Help
Guest shadowake
Guest shadowake
Hi after I do about 5 miles a big red triangle with an exclamation mark in the middle of it pops up in the rev counter :Pling: any idea what this means, also after about 10 miles a light randomly flashes saying slip cont off :blink:
Any help apreciated.
Hi shadowake,
Look up the error code(s) like wallace9 suggested. My guess is that it'll be code 42 (speed sensor error). If so, there are *loads* of threads that discuss code 42 on here, and don't worry, you probably won't need a new speed sensor! :)
PS in future, you might get more technical responses posting in the "supra chat" section rather than "new members" :)
Is your ODO connected and working properly?
Could it be something to do with my speedo being changed to mph and delimited?
Quite possibly. Best to check what the error code is first, but if it is code 42, then a faulty Digital Speed Converter (DSC) and Top Speed Delimiter (TSD) are often the culprits. A faulty DSC caused mine.
