Trig Posted June 25, 2007 Share Posted June 25, 2007 So if i got a harness where could i mount it to? (If i didnt have a harness bar) Maybe something like this? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=020&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=300090610140&rd=1&rd=1 Quote Link to comment Share on other sites More sharing options...
SimonB Posted June 25, 2007 Share Posted June 25, 2007 So if i got a harness where could i mount it to? (If i didnt have a harness bar) Maybe something like this? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=020&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=300090610140&rd=1&rd=1 First I'd never use 3 point harnesses. As you move forward in an impact the shoulder straps would want to pull together - not nice. Second, just buy a harness bar. They look good, secure the shoulder straps at the correct angle with as short a strap as possible which minimises the amount the belts will stretch in an impact and aren't that expensive. No brainer IMO. Quote Link to comment Share on other sites More sharing options...
Trig Posted June 25, 2007 Share Posted June 25, 2007 Ok, harness bar it is. Where did you get yours from Si and how much? Think i may have asked you this a while ago but cant find the PM. Would this be better? http://cgi.ebay.co.uk/Sparco-4-Point-Driver-Harness-Bolt-In-SILVER_W0QQitemZ300090656281QQihZ020QQcategoryZ72228QQrdZ1QQcmdZViewItem or this? http://cgi.ebay.co.uk/SABELT-50MM-4-POINT-HARNESS-PUSH-BUTTON-BUCKLE-BOLT_W0QQitemZ290091825955QQihZ019QQcategoryZ72228QQrdZ1QQssPageNameZWD1VQQcmdZViewItem Quote Link to comment Share on other sites More sharing options...
paul mac Posted June 25, 2007 Share Posted June 25, 2007 Ok, harness bar it is. Where did you get yours from Si and how much? Think i may have asked you this a while ago but cant find the PM. Would this be better? http://cgi.ebay.co.uk/Sparco-4-Point-Driver-Harness-Bolt-In-SILVER_W0QQitemZ300090656281QQihZ020QQcategoryZ72228QQrdZ1QQcmdZViewItem or this? http://cgi.ebay.co.uk/SABELT-50MM-4-POINT-HARNESS-PUSH-BUTTON-BUCKLE-BOLT_W0QQitemZ290091825955QQihZ019QQcategoryZ72228QQrdZ1QQssPageNameZWD1VQQcmdZViewItem these are both 2" harnesses (not as good) i would try and go for the 3", MVP (on this forum) do the harness bar, very good rates at shipping Quote Link to comment Share on other sites More sharing options...
SimonB Posted June 26, 2007 Share Posted June 26, 2007 Yeah, I got mine from MVP (harness bar that is). As for the harnesses, you need to make sure you get ones where the shoulder straps are designed to go round a roll bar rather than bolt in. For the lap belts the easiest thing is to go for bolt in - if you get snap-in ones you have to put eye bolts in to clip them to which is a pain, but does make them easier to remove if you want to. I bought top-end harnesses because I wanted decent aircraft style quick-release buckles, lightweight shoulder adjusters and the ability to use 6 point harnesses. Mine are Sparco and came from a company called rallynuts that have a huge range. Quote Link to comment Share on other sites More sharing options...
